OjaiM5
OjaiM5 HalfDork
2/8/25 11:20 a.m.
I am thinking not. I took my front wheel off of my new to me car and found this spacer. I am guessing that the wheel needs to be hub-centric to the spacer. I hate when people buy stupid stuff like this. Also makes me wonder if the lugs are getting enough thread.
dps214
dps214 SuperDork
2/8/25 11:33 a.m.
Stud length looks like it could be a concern. Any wheel that uses a tapered seat lug interface is actually lug-centric not hub-centric. The only thing the lack of hub flange really does is make installing the wheel more annoying.
2/8/25 12:19 p.m.
i concur
OjaiM5
OjaiM5 HalfDork
2/8/25 12:48 p.m.
Interesting, Thank you. I will check the safety if the threads
03Panther
03Panther PowerDork
2/8/25 12:51 p.m.
i concur
The stud length would be my only concern. At a glance it looks ok to me, but thickness of wheel? The tapered lug nuts should have 1 1/2 times the dia. thread engagement.
if 1/2-20 studs, 3/4" engagement
cyow5
cyow5 HalfDork
2/8/25 12:53 p.m.
Another thing I've noticed with non-centric spacers is that you can pick up some vibration if they are way off. I just get the nuts finger-tight then push the spacer edges by hand until they are roughly even around the circumference. Granted, my Elise has only ~400lbs on each front corner, so it doesn't take a whole lot of imbalance to notice something, but it is noticeably smoother when I do this extra step.
2/8/25 1:53 p.m.
I would prefer that the spacer have a way of centering itself, but the red flag I see is that the spacer appears to be a smaller diameter than the OD of the wheel's hub face.  This can cause weird issues as the wheel flexes.  (Wheels flex.)  If you had a steel wheel, an undersized spacer like that can actually chew through the coining, leading to a two piece wheel.
yes they do. good catch.
OjaiM5
OjaiM5 HalfDork
2/8/25 2:41 p.m.
I think I will pull them off. I'm sure the car looks cooler with them on but I am not feeling to confident about them.
Be sure they weren't using them for brake clearance or suspension clearance but you'll figure that out real fast if they did.
2/8/25 10:45 p.m.
Sharing this with hopes it helps someone.
2/8/25 10:45 p.m.
(By the way, I once had some wheels/spacers that didn’t pass.)
z31maniac
z31maniac MegaDork
2/9/25 8:38 a.m.
Spacers are just blocks of metal, that looks like it may a hub adapter to use wheels with a different bolt pattern.
DeadSkunk  (Warren)
DeadSkunk (Warren) MegaDork
2/9/25 9:18 a.m.
In reply to z31maniac :
It's just a universal spacer. It has elongated holes for various bolt circle diameters and there are four-hole and five-hole patterns. I've got a similar pair someplace.
CxGulm011mrDlu7blCzEOSQuAXnYUxG9MftJSQgbApDC2Pnq6ONAgM4wdfUqjCX9
