Somebeach (Forum Supporter)
Somebeach (Forum Supporter) Reader
1/4/21 11:34 a.m.
Working on challenge driveshaft.
I got two from the junkyard Saturday for their yokes. I know I need to melt the plastic out to get the u joints undone, but is there a way to get the "collar" off? I didn't see how that part went together.
I want to get rid of the part with the pink arrow going to it, but keep the actual slip yoke (green arrow part)
newrider3
newrider3 Reader
1/4/21 12:49 p.m.
What do they look like from either the front or back side? Can you see a rubber isolation layer in between the ring and the yoke, kind of like an crankshaft damper?
obsolete
obsolete GRM+ Memberand New Reader
1/4/21 1:04 p.m.
I got a junkyard shaft from an S10 that has that big damper on it too. It is rubber-isolated. I think they can be pulled off but I haven't tried yet, so I'll be watching this :)
1/4/21 4:55 p.m.
In reply to newrider3 :
Yup, I must have missed that Bc of the dirt. But both have rubber between the collar and the rest of it.
will it just pull off then? Or hammer off ?
obsolete
1/4/21 5:26 p.m.
Maybe a big jaw puller would do it? Or stick the yoke in a shop press once you separate it from the driveshaft.
newrider3
newrider3 Reader
1/4/21 9:09 p.m.
Make two or three cuts through the outer ring using a cutoff wheel. Then if the rubber is deteriorated enough it will just fall off; if it's still adhered then it may take some prying. More trouble than it's worth trying to pull it off in one piece.
42A4ZiuGjiRf8k6cc43AXdDMLkhFrfhdyLGU3UjZc9JgvfwQSPDZKpk2Vv0zkcJ3
