pigeon
pigeon HalfDork
7/4/10 6:04 p.m.
Surfing C-list pays off - just scored an 87 325is for $500 3 hours after it was listed. Still haven't seen it - no pics in the ad - but it's got the 4.10 LSD, BavAuto springs, short shifter and catback, supposed to be only limited rust on the driver's door. Dark gray with tan interior.
The bad: power steering rack leaked so the current owner pulled the pump and drained the rack 3 years ago - still has the pump and I intend to rebuild the rack this winter. Hesitates just off idle, current owner has looked without finding any vac leaks. Suggestions? Has a small oil leak when warm on the right side, oil cooler seals are said to be dry - any ideas? May need a thermostat per the ad, will talk to the owner more about that when I go test drive it. Tires are mismatched but supposed to be in good condition.
I'll post pics after I pick it up, hopefully tomorrow.
stuart in mn
stuart in mn SuperDork
7/4/10 9:14 p.m.
There's a seal on the bottom of the oil filter casting that can leak, it is associated with the oil cooler: http://e30.bmwdiy.info/oil-leak/index.html
pigeon
pigeon HalfDork
7/4/10 10:54 p.m.
Good info - thanks!
I need to see when the timing belt was last done, and if not verified by receipts change it. Seller is a local BMWCCA member and enthusiast who owns an E36M3 so hopefully it was kept up to date.
plance1
plance1 HalfDork
7/5/10 7:48 a.m.
old lincolns are cool, must post photos soon.
t3LL9rqDeyUayOLmrLqk30iQcLXmZ1981yAGO6kbCUKFOYn1nxX31fztGjmMbODm
