7/28/22 12:50 p.m.
Sponsored content presented by Sunoco.
A common question Sunoco’s Race Fuel department receives: Is this fuel fresh?
The short answer is often yes, but as explained by Zachary J. Santner, senior specialist of quality at Sunoco, the full reply is usually longer. Don’t worry, he notes, the longer reply delivers the same answer: The fuel is fresh.
Sunoco usually …
Daniel Wise
Daniel Wise GRM+ Memberand New Reader
7/28/22 1:20 p.m.
"Santner offers an additional storage tip: Keep that cap tightly closed. A loose cap–or even drum pump–can allow the vapors to escape, causing the fuel to go stale. As long as the container remains tightly sealed, he explains, any vapors will condense back into a liquid phase, maintaining the fuel’s freshness."
The above is extremely important.  The larger drums, 30 and 55 gallon drums may not always seal up vapor tight.  That means as the temperature changes the drum "breathes" through the drum bung plug.  If there is standing water on the top of the drum, it will get sucked into the drum when the weather cools off and your fuel is now contaminated.  Make sure the bung is tight and the top of the drum is covered to prevent standing water accumulation.  Personal experience.
J.A. Ackley
J.A. Ackley Senior Editor
8/6/24 2:27 p.m.
I don't know if it applies to anyone here, but if there's a fuel rule (like at some oval tracks) and they send a sample to the lab, racers who use older fuel may not pass as its composition changes over time.
8/7/24 9:45 a.m.
While working on this, Zach and I found plenty of forum threads with people discussing how they vent their fuel cans when the pressure gets too high. Zach was like, Now you’re letting out the good stuff.
f0ypYexpWGtALeEb9ot8vLbvojOANX3cBLfuFzkn9kpPBiozm2W5wDVODIwTaTfA
