Platinum90
Platinum90 SuperDork
12/18/10 7:52 p.m.
Bench racers and Engineers rejoice. I have a brain exercise for you to ponder.
The current lap record at Laguna Seca is 1 minute 5.88 seconds set by Sebastien Bourdais in 2007 in a Panoz Champ Car.
If you were going to engineer a car to beat it, cost is given no consideration. The only "rule" is that it be a car... ie, has four wheels on the ground, and a fifth for steering.
Who would drive it, what engine would power it, and what would it resemble?
To make the situation even more difficult, do you think it could be done within the SCCA's Solo II E Modified rules, and what would it take?
Basically, what car would you want if it's only goal were to annihilate overall track records?
Platinum90
12/18/10 7:55 p.m.
For comparison, this is one of the nations quickest E modified cars. 3 rotor Mazda powered AH Sprite.
Toyman01
Toyman01 GRM+ Memberand SuperDork
12/18/10 8:15 p.m.
Money no object...this.
grafmiata
grafmiata Dork
12/18/10 8:20 p.m.
Dasia Sandero with a Veyron driveline, and some sort of KERS system.
dean1484
dean1484 Dork
12/18/10 8:22 p.m.
Toyman01 wrote: Money no object...this.
/thread
tuna55
tuna55 Dork
12/18/10 8:23 p.m.
Spend enough to develop a top fuel engine into something that could last that long and deal with varying throttle inputs and put it into an F1 style car with way more aerodynamics since the horsepower (and therefore drag) is basically unlimited in the name of downforce.
Smack35
Smack35 Reader
12/18/10 8:36 p.m.
I would probably use the Honda V12 from Ayrton Senna's McLaren MP4/6. I would put that in a Stohr D Sports Racer. It would have 13inch OZ racing wheels with 12in wide Hoosiers at the back, and 13in OZ wheels with 10in wide Hoosiers at the front. Brakes would probably be 2 piston with Hawk pads. Shocks would be Penske double adjustables all around with Eibach springs: 700lb springs in the front and 800lbs in the rear.
Gordon Shedden, Leh Keen, Scott Pruett and Juan Pablo Montoya would beg me to drive it, so I guess I'd let them. But to make it go fast I'd have Vitaly Petrov drive it....yes, Vitaly Petrov.
Steven
MCarp22
MCarp22 Reader
12/18/10 8:45 p.m.
With modern engine management and turbocharger tech.
JFX001
JFX001 SuperDork
12/18/10 9:03 p.m.
Something with VTEC....and lotsa NOS.
Streetwiseguy HalfDork
12/18/10 9:04 p.m.
I'd go with this, modernized engine components and electronics, with modern tires tech. I just like 'em.
Platinum90
12/18/10 9:11 p.m.
I have always wanted to see a modern interpretation of 1970 Can Am rules...
loosecannon
loosecannon New Reader
12/18/10 9:57 p.m.
In 1973, Mark Donohue's qualifying time at Laguna Seca 0:57.374, but maybe the track has been changed since then. I suspect that a 917-30 in qualifying trim on modern tires would still be the quickest car around the track.
MCarp22
MCarp22 Reader
12/18/10 10:47 p.m.
loosecannon wrote: In 1973, Mark Donohue's qualifying time at Laguna Seca 0:57.374, but maybe the track has been changed since then. I suspect that a 917-30 in qualifying trim on modern tires would still be the quickest car around the track.
The track is about .4 miles longer now.
friedgreencorrado
friedgreencorrado SuperDork
12/19/10 12:31 a.m.
Track was changed in 1988 because they wanted to host a round of the Motorcycle GP. They added the section from Turn 2 to Turn 5 to make the place long enough to suit the rules. It used to be straight through, instead of making that detour into what used to be the infield.
Only map of the original circuit I can find is over at racingsportscars.com, which doesn't allow hotlinking. So, here's a lap in the old Group 44 Jag GTP car from 1985.
http://www.youtube.com/watch?v=H9HITyw2jIw
WilberM3
WilberM3 HalfDork
12/19/10 12:45 a.m.
found a pic.... looks like it was kind of boring expect for the corkscrew section
11110000
11110000 Reader
12/19/10 6:17 a.m.
I wonder how much time could be gained in the corkscrew by using an active downforce system, like the Chaparral?
Platinum90
12/19/10 7:35 a.m.
Track was changed in 1988 because they wanted to host a round of the Motorcycle GP. They added the section from Turn 2 to Turn 5 to make the place long enough to suit the rules. It used to be straight through, instead of making that detour into what used to be the infield. Only map of the original circuit I can find is over at racingsportscars.com, which doesn't allow hotlinking. So, here's a lap in the old Group 44 Jag GTP car from 1985. http://www.youtube.com/watch?v=H9HITyw2jIw
Holy Carp! That track setup would have been WICKED fast. Without the Andretti hairpin, the last corner would really be the only slow part on the track and the average speed would be sky high.
Thanks for that Jay.
eastpark
eastpark Reader
12/19/10 7:46 a.m.
This - with modern engine management:
Drewsifer
Drewsifer HalfDork
12/19/10 7:56 a.m.
R500 is go?
triumph5
triumph5 Dork
12/19/10 7:56 a.m.
WilberM3 wrote: found a pic.... looks like it was kind of boring expect for the corkscrew section
I can assure you it was FAR from boring...and does any does anyone remember the oak tree at the top of the corkscrew?
Type Q
Type Q HalfDork
12/19/10 11:15 a.m.
When I was at the historic races there a few years ago, Toyota brought one of the their F1 cars out for a run at the lap record. I guess its been surpassed by now. I am guessing that any top tier F1 or champ car team configuring wings and such without a rule set confining them could get under that record.
WilberM3
WilberM3 HalfDork
12/19/10 11:52 a.m.
triumph5 wrote: I can assure you it was FAR from boring...and does any does anyone remember the oak tree at the top of the corkscrew?
yea, boring was probably the wrong word... just reminds me of lime rock where all the corners but one go one direction. i suppose the tremendous speed would make it interesting.
was there a peculiarly not removed oak tree up there?
oldsaw
oldsaw SuperDork
12/19/10 12:54 p.m.
yea, boring was probably the wrong word... just reminds me of lime rock where all the corners but one go one direction. i suppose the tremendous speed would make it interesting. was there a peculiarly not removed oak tree up there?
IIRC, that oak tree was always on the outside of the track, behind the run-off area and the barriers. It is/was (maybe replaced by other trees) used as a sighting-point for drivers approaching the Corkscrew. And those trees are growing from an area 20'-30' below track level.
It's not unlike the trees used by drivers setting-up their entrance at the 'Ring's Karoussel.
Osterkraut
Osterkraut Dork
12/19/10 1:18 p.m.
For funsies? Gas turbine, independent electric motors for each wheel (mounted inboard, of course), vacuum downforce with some sort of computer trickery so it shuts off in the straights.
The 100 pound brains can work out the rest.
WilberM3
WilberM3 HalfDork
12/19/10 1:22 p.m.
there's a tree like that at Mont-Tremblant going over the blind turn 2 apex, when youre learning the track just aim for the white bitch tree and you'll be in the right spot
Dqag1fno07lYuzOULF9yfO6gFUheRTn4ciQRu8KufVm8TWLqgblYyYHvsnFF3PJs
