Taiden
HalfDork
6/11/11 2:06 p.m.
Alright, sooooo yeah. It's raining here in beautiful Maine, and I decided whilst at a stand still to launch my 318i. Rev to about 4.5k and ceremoniously dump the clutch (but not in a side-stepping fashion, slightly more gentle).
The car bogged down and proceeded to run like ass.
At first I was sure that it was my AFM stuck wide open, as was previously the issue. At first it was running, but would hardly operate under load. After checking a few things, the car won't even run now. It just sputters randomly.
The things that I checked:
- vacuum lines
- AFM
- all visible EFI related plugs
- checked for loose plug wires
- checked for damaged cap/rotor
- cleared the engine to check for flooding
The car is currently on the side of the road somewhere and I will be returning to it to try some other things. Any ideas would be appreciated.
Take the distributor cap off and see if its all in-tact in there (assuming E30 318 since you said AFM and not MAF...).
maybe you got water somewhere it shouldn't have been? Generally a launch only breaks mechanical things that make the car go.. not parts that make the engine run
Taiden
HalfDork
6/11/11 2:23 p.m.
Snorkle: I did check, but I have a spare rotor here that I'll throw in for the hell of it.
Mad_Machine: I know... it's totally stumped me. I've never heard of this happening before. I may just have to go through the motions.
318i uses a timing belt or a chain?
Might need to check your timing.. both at the distributer and the cam
ww
SuperDork
6/11/11 3:31 p.m.
Is that an answer or a question?
I assume your timing chain slipped?
It's broke. Sounds timing related as it seems to want to run, but doesn't.
Taiden
HalfDork
6/11/11 4:28 p.m.
Sorry. I found it. Pretty funny, had excellent spark at all four plugs, swapped in a spare AFM, car still didn't run, but it was backfiring sporadically.
Pulled the cap off, and turned the rotor. Uhmmm. I don't think rotors are supposed to turn 360* when the crank isn't moving.
$7.60 later at a NAPA that was a 1/4 mile away and I was on the road again.
The culprit:
{sarcasm} Awesome Made in USA part.{/sarcasm}
Taiden
HalfDork
6/11/11 7:53 p.m.
We had a good laugh about that.
So you ceremoniously dumped the clutch when leaving the NAPA parking lot, right?
Taiden
HalfDork
6/11/11 8:51 p.m.
In reply to MitchellC:
Sure did, but in a more timid manner.
Taiden
HalfDork
6/12/11 6:52 p.m.
Snorklewacker, you win the pride of winning!
Unless you want the old rotor. It was going to go on my wall of shame, but you can have it if you like.
