3Door4G
3Door4G Reader
6/10/10 7:24 a.m.
So I don't need an introduction to the world of alcoholism, thanks anyway. I'm talking about suspension bars here.
I understand the basics of sway bars- they tighten the lower end of the chassis. Too thick in the front can increase understeer, and too much in the rear can increase oversteer... etc etc
But what about strut bars? Is there a time when a sway bar would not be appropriate for an application but a strut tower bar would? And if so, why? Is it just that the effect is milder? And if so, wouldn't a thinner sway bar do the trick?
SO MANY QUESTIONS!
HappyAndy
HappyAndy HalfDork
6/10/10 7:34 a.m.
A strut bar and sway bar are for completly different jobs, a strut bar is for reducing chassis flex common in mac-strut equiped cars. not all mac-strut cars flex enough to need one, and there was an article in a recent grm about chassis set up that went into detail about that.
As for sway bars, what you mentioned about front/under steer and rear/oversteer is generaly true for FWD cars and it is often the other way around on RWD cars, but every car is different so it would help to know what type of car you have in mind.
914Driver SuperDork
6/10/10 7:37 a.m.
My understanding of strut bars is they reenforce the unibody. Look at a car from the front, lower horizontal cross member and a vertical upright at each end. Looks like the letter "U". The strut bar across the shock towers connects the top of the "U" making a box; more rigid than a U.
My old 914 was so loose that a bump at the right angle would pop the engine compartment cover open.
Strut bars in the trunk do the same thing. The rear floor pan on my BMW 2002 under the rear seat was called a "torsion box". I have no idea why or what it did, but I'm guessing taking a Saw-Zall to it would be bad.
Dan
DaveEstey
DaveEstey Reader
6/10/10 7:40 a.m.
Sway bars do not tighten the chassis... They connect the suspension right and left, transferring torque from the compressed outside tire in a turn to the inside, thus reducing roll.
iceracer
iceracer Dork
6/10/10 10:22 a.m.
The stiff front, soft rear = understeer holds true regardless of the drive wheels. The effect of the drive wheels is the problem .
carguy123
carguy123 SuperDork
6/10/10 10:29 a.m.
iceracer wrote: The stiff front, soft rear = understeer holds true regardless of the drive wheels.
Thank you, I thought I was going crazy and everything I knew was false.
amg_rx7
amg_rx7 HalfDork
6/10/10 10:39 a.m.
Here is a link to GRM articles on sway bars, shocks etc:
http://grassrootsmotorsports.com/articles/category/tech/suspension/
96DXCivic
96DXCivic Dork
6/10/10 10:42 a.m.
Strut bars are used to stiffen the chassis. However they promise a lot but they don't always provide. Cheap eBay strut bars probably won't do too much. The strut bar is most useful if they are triangulated like the one seen below.
Swaybars are basically torsion springs which connect the sides of the car. When the car rolls in a turn, the bar twists and restricts the roll of the vehicle. I have all the equations to calculate how much it will restrict the roll. Let me know if you want to post these.
tuna55
tuna55 HalfDork
6/10/10 10:58 a.m.
Go over to corner carvers and tell them how much stiffer your car will be with your new strut bar off of ebay.
Then run.
njansenv
njansenv Reader
6/10/10 11:03 a.m.
Depending on suspension geometry, a stiffer front bar can DECREASE understeer. Common with Macstrut front suspension.
Reason: less body roll = better outside front contact patch.
Carson
Carson Dork
6/10/10 11:09 a.m.
96DXCivic wrote: I have all the equations to calculate how much it will restrict the roll. Let me know if you want to post these.
Yes please. I has thirst for knowledge!
96DXCivic
96DXCivic Dork
6/10/10 11:22 a.m.
Ok but how do you post a pdf?
Capt Slow
Capt Slow HalfDork
6/10/10 2:48 p.m.
you need to upload it to the web, most people do this through a hosting service.
If you use gmail for your email, that means you have access to google docs which may afford you some options in this regard (I think).
96DXCivic
96DXCivic Dork
6/10/10 2:53 p.m.
http://docs.google.com/fileview?id=0BxJNiOGL1WdeN2M5MGVmNWYtMjEwMy00NjYzLThlNzQtM2Q4ZDVlMWUxYzI5&hl=en
I hope this works.
Edit: Yup it works.
Tom Heath
Tom Heath Webmaster
6/10/10 2:57 p.m.
amg_rx7 wrote: Here is a link to GRM articles on sway bars, shocks etc: http://grassrootsmotorsports.com/articles/category/tech/suspension/
amg_rx7 wins 1 sticker. PM me your address, please.
Tom Heath
Tom Heath Webmaster
6/10/10 3:02 p.m.
Depending on suspension geometry, a stiffer front bar can DECREASE understeer. Common with Macstrut front suspension. Reason: less body roll = better outside front contact patch.
The relative relationship in bar size front to rear is still affecting the balance of said car.
In dungeons and dragons terms, consider it +1 roll stiffness, -1 weight transfer. Still worthwhile in some cases, stock class autocrossing comes to mind.
Tom Heath
Tom Heath Webmaster
6/10/10 3:05 p.m.
Just like you would a photo. You may want to convert it to an image first.
Tom Heath
Tom Heath Webmaster
6/10/10 3:05 p.m.
TRIPLE POST COMBO!
Gearheadotaku
Gearheadotaku GRM+ Memberand Dork
6/10/10 7:30 p.m.
D&D referece! WIN!!!! (I still can't make quotes work right)
3Door4G
3Door4G Reader
6/14/10 9:53 p.m.
I think I'm finally getting it.
I bookmarked that link. And this thread.
I'm trying to figure out suspension because my Civic will be getting new pieces soon. It's a daily driver and I'm very poor, so I want to get it right the first time.
DaveEstey
DaveEstey Reader
6/14/10 10:03 p.m.
custom spring rates, front 400lbs rear 500lbs. Stock front sway and 22mm ST rear bar. Add some good shocks and you're done!
AngryCorvair
AngryCorvair GRM+ Memberand SuperDork
6/14/10 10:59 p.m.
3Door4G wrote: I think I'm finally getting it. I bookmarked that link. And this thread. I'm trying to figure out suspension because my Civic will be getting new pieces soon. It's a daily driver and I'm very poor, so I want to get it right the first time.
how to get it right the first time, poor person daily driver edition:
LEAVE IT THE berkeley ALONE! HONDA ENGINEERS ARE SMARTER THAN YOU!
3Door4G
3Door4G Reader
6/14/10 11:18 p.m.
I can't come up with any rational argument against the above statement. I don't believe there is one. So I'm not going to try.
I'm still going to go ahead and drop the car though. This is still a project car, just a very slowly progressing one. It's taken me almost a year to get the exhaust right.
neon4891
neon4891 SuperDork
6/14/10 11:20 p.m.
how to get it right the first time, poor person daily driver edition: LEAVE IT THE berkeley ALONE! HONDA ENGINEERS ARE SMARTER THAN YOU!
FTMFW!!!
ZOO
ZOO GRM+ Memberand Dork
6/15/10 6:20 a.m.
Gearheadotaku wrote: The relative relationship in bar size front to rear is still affecting the balance of said car. In dungeons and dragons terms, consider it +1 roll stiffness, -1 weight transfer. Still worthwhile in some cases, stock class autocrossing comes to mind. D&D referece! WIN!!!! (I still can't make quotes work right)
Leave it to a guy with an X-11 in his avatar to quote D and D!
No offense meant -- I loved both in the 1980's, too. Especially since the X-11 was kind of obscure, and quite elegant looking in its simplicity.
DNZwhFzaIOrXCMFbLXIqUT0IbvBA9uP9pGsc5CtqfxCrhdASooBkdHlC1Ax4ttLz
