Kenny_McCormic
Kenny_McCormic UltraDork
12/1/13 2:00 p.m.
So I'm working on my Prizrolla, had the belt off to move the alternator, to change the thermostatic fan switch on the thermostat housing. I make the stupid, stupid decision to have a look around while I'm in there. Found out my tensioner pulley bearing has about 2mm of side to side play in it, pulley is also pretty worn. Ok so that's what that whine it's made since I bought it is! So I'll go buy one off rockauto and throw it on in the parking lot, NBD. Then I looked at the bolt holding the berkeleyer on.
Turns out I would need one of these. http://www.ebay.com/itm/Toyota-Altis-Special-HEX-Ribe-Socket-1-2-Dr-M10S-/281209594175?pt=Motors_Automotive_Tools&hash=item417965e13f&vxp=mtr
Does horror freight sell something that will work? Am I gonna have to spend $10 on a single socket I'll use once?
Ranger50
Ranger50 PowerDork
12/1/13 2:12 p.m.
try one of those all in one sockets?
AquaHusky
AquaHusky Reader
12/1/13 2:18 p.m.
Just means they think you shouldn't be touching it at all.
benzbaronDaryn
benzbaronDaryn Dork
12/1/13 2:46 p.m.
Didn't sears or one of those guys sell some stupid multitool with a thing to remove splined nuts. I remember seeing the advert and wondering who uses spline nuts. 10$ ain't nothing for a tool you'll only use once.
Kenny_McCormic
12/1/13 2:46 p.m.
In reply to AquaHusky:
No, it means they want me to buy a $100 tensioner assembly, instead of the $12 sub assembly that actually wears out.
Kenny_McCormic
12/1/13 3:00 p.m.
benzbaronDaryn wrote: Didn't sears or one of those guys sell some stupid multitool with a thing to remove splined nuts. I remember seeing the advert and wondering who uses spline nuts. 10$ ain't nothing for a tool you'll only use once.
Yeah, on a Benz maybe.
You're thinking of this http://www.sears.com/craftsman-19-piece-inch-and-metric-universal-socket/p-00924963000P?prdNo=3&blockNo=3&blockType=G3 different spline setup.
novaderrik
novaderrik PowerDork
12/1/13 3:11 p.m.
a 12 point socket won't fit "good enough" to get it apart?
Kenny_McCormic
12/1/13 3:15 p.m.
No way, look at the spline spacing. Maybe a pipe wrench would work and then I'd have to get a ride to a hardware store and source a new hex head bolt.
AquaHusky
AquaHusky Reader
12/1/13 3:42 p.m.
In reply to Kenny_McCormic:
That sounds like your best bet right there. If you have the room to accomplish it.
Kenny_McCormic
12/1/13 3:43 p.m.
At that point I'd rather just spend $11 on the right tool and be done with it.
Knurled
12/1/13 3:52 p.m.
You mean the hydraulic doodad that fails all the time actually lasted longer than the pulley?
DrBoost
DrBoost PowerDork
12/1/13 3:52 p.m.
Where in MI are you? I think I have a set of those already.
Kenny_McCormic
12/1/13 3:58 p.m.
In reply to Knurled:
Seems to work? Stiff to wind up. I just don't know WTF was wrong with the old pivoting alternator trick.
In reply to DrBoost:
Detroit proper, quite a ways out from Fenton. I appreciate the thought though.
DrBoost
DrBoost PowerDork
12/1/13 7:29 p.m.
I work in Rochester Hills......
IM me if you wanna give it a go.
SlickDizzy
SlickDizzy GRM+ Memberand UberDork
12/1/13 7:54 p.m.
Harbor Freight has those sockets, the bellhousing bolts on my E28 needed the same thing.
Kenny_McCormic
12/1/13 7:58 p.m.
In reply to SlickDizzy:
Link me? I'm only seeing the "universal" spline sockets(wrong), and reverse torx.
mblommel
mblommel GRM+ Memberand Reader
12/1/13 7:58 p.m.
TIG weld a regular nut onto it?
HappyAndy
HappyAndy SuperDork
12/1/13 8:00 p.m.
Is that the type of fastener that is sometimes referred to as reverse or inverted torx?
SlickDizzy
12/1/13 8:01 p.m.
Kenny_McCormic wrote: In reply to SlickDizzy: Link me? I'm only seeing the "universal" spline sockets(wrong), and reverse torx.
You are actually correct, upon further inspection I see how that socket differs from the reverse Torx I was thinking of. Sorry to get your hopes up!
Kenny_McCormic
12/1/13 8:12 p.m.
A picture of the whole thing, not torx.
Dr. Hess
Dr. Hess MegaDork
12/1/13 8:32 p.m.
Vice Grips?
Hal
Hal SuperDork
12/1/13 8:34 p.m.
Looks like you could use a Gator Grip Socket. I also found them listed at HF, Sears and Lowes.
RealMiniDriver
RealMiniDriver UltraDork
12/1/13 8:36 p.m.
Hell, I'd spend the eleven bucks and fix the thing.
JoeyM
JoeyM GRM+ Memberand Mod Squad
12/1/13 8:43 p.m.
Dr. Hess wrote: Vice Grips?
I always end up rounding/ruining bolts that I try that with.
Do you think these would work? http://www.harborfreight.com/hand-tools/sockets-ratchets/9-piece-38-drive-metric-bolt-extractor-sockets-67894.html
JoeyM
12/1/13 8:47 p.m.
Or these? http://www.harborfreight.com/hand-tools/sockets-ratchets/7-piece-1-2-half-inch-metric-spline-socket-set-96363.html http://www.harborfreight.com/hand-tools/sockets-ratchets/7-piece-3-8-eighth-inch-metric-spline-socket-set-96362.html
wGvDQua2ZGH7qN8kQpbZRdWs5V8h8xifrMnx5WgZl3IMoXN8qxLUAp7kBgcuf8HN
