racerboy000
racerboy000 New Reader
2/1/10 8:42 p.m.
I bought a 1999 legacy wagon and would like to make it handle better (rear sway bar) and shift better. Is there any cheap mods parts from another subbie to make it a bit more fun to drive?
mtn
mtn SuperDork
2/1/10 8:57 p.m.
WRX suspension parts. If you look hard enough you can find it cheap-ish.
Hocrest
Hocrest Reader
2/1/10 8:59 p.m.
What trans does it have? What trans do you want?
irish44j
irish44j Reader
2/1/10 9:05 p.m.
IDK if it's verboten to link to another forum, but....
try nasioc (ignore the fanbois along the way) It's technically an impreza/wrx/sti forum but alot of legacy and other subies there too. you should be able to research what wrx parts fit your leggy and then find them used there too....
judging by what I've seen on most leggies, the first order of business should be better tires.
try this link to the legacy section and note the stickies... http://forums.nasioc.com/forums/forumdisplay.php?f=13
aussiesmg
aussiesmg SuperDork
2/1/10 9:09 p.m.
WRX engines fit in there nicely, just so you know
Opus
Opus Dork
2/1/10 11:28 p.m.
irish44j wrote: IDK if it's verboten to link to another forum, but....
I don't know, I hear GRM HATES Subies.
ddavidv
ddavidv SuperDork
2/2/10 5:33 a.m.
WRX suspension won't work if it's an Outback. They have welded in spring spacers on the chassis. Regular Legacy models are ok.
Most of the secrets lie on NASIOC if you're willing to spend time wading through the searches.
racerboy000
2/2/10 6:04 a.m.
5 spd tranny
MCarp22
MCarp22 Reader
2/2/10 8:49 a.m.
I had a legacy specific whiteline front swaybar, and it made the car handle a whole lot better.
SlickDizzy
SlickDizzy GRM+ Memberand SuperDork
2/2/10 10:53 a.m.
Skip NASIOC, go to Ultimate Subaru (www.ultimatesubaru.org) and Legacy Central (www.legacycentral.org) instead. More knowledge, less BS.
If your car is an automatic Outback, pretty much all the fun has been dialed out from the factory, I'd sell the car before I put money into an auto. Swapping control arms will let you run regular Impreza/Legacy bits. IIRC if you look around there are Bilsteins spec'd for the Outback, and there are a few sets of stiffer springs that will work.
racerboy000
2/6/10 7:24 a.m.
Got it home, it drives really nice, cuise and all that jazz.
racerboy000
2/6/10 7:26 a.m.
I hope to pick up a short shifter for it this week and order a rear sway bar next from ipd
ValuePack
ValuePack HalfDork
2/7/10 2:24 p.m.
SlickDizzy wrote: Skip NASIOC, go to Ultimate Subaru (www.ultimatesubaru.org) and Legacy Central (www.legacycentral.org) instead. More knowledge, less BS.
This. /thread
GZfd3EoZNWeVLUQZJt8H7IGGUcZNxY5FCRXMGxhbUKXf9op16wlxFpajOkzMEMEM
