logicfactory
logicfactory New Reader
11/10/11 6:36 p.m.
i found one source that said a crx had an ~7lb rotor. there appears to be a lack of precision with that weight so i come here to investigate the matter further. based on all the time i have spent looking at the wilwood rotors i would image the best solution would be a non-vented/solid rotor.
can anyone add a specific rotor weight that can act as a benchmark?
novaderrik
novaderrik Dork
11/10/11 9:28 p.m.
different rotors will weigh more or less depending on how much metal is in them and what alloys they use. some of the "premium" vented rotors will have thicker wear surfaces and weigh more than their cheaper counterparts..
Streetwiseguy Dork
11/10/11 9:40 p.m.
Are you looking for the lightest rotor that meets a spec, or simply the lightest rotor?
The rears on my B13 SER Sentra are seriously tiny. And thin. And I think I paid about $12 each for new ones.
logicfactory
11/10/11 11:13 p.m.
i will try and find a weight for those rotors tomorrow; thank you.
as for your question; i am looking for the lightest rotors.
ditchdigger
ditchdigger Dork
11/10/11 11:16 p.m.
http://brembo.mycarparts.net/
If you search by vehicle, in the images section is the CAD file with weight included.
EvanR
EvanR Reader
11/11/11 12:50 a.m.
1985 Chevy Sprint. And Rock Auto has some on sale right now for $5.44 each.
2002maniac
2002maniac HalfDork
11/11/11 4:07 a.m.
What's the intended application? I have 72 gram rotors on my mountain bike, but I don't think that's what you're after...
DaewooOfDeath
DaewooOfDeath HalfDork
11/11/11 4:36 a.m.
What is your application?
wbjones
wbjones SuperDork
11/11/11 6:28 a.m.
no-name Chinese made rotors (vented) (used... therefore a bit thinner than new) = 8.5 lb
ProDarwin
ProDarwin Dork
11/11/11 7:11 a.m.
2002maniac wrote: What's the intended application? I have 72 gram rotors on my mountain bike, but I don't think that's what you're after...
This. And what's the budget?
If it needs to be $cheap and available, the rears of something old, FWD, and light are probably the ticket.
1.6l NA miata rears?
16vCorey
16vCorey SuperDork
11/11/11 7:39 a.m.
Base Model Rabbits, Golfs, and Jettas have a 9.4" solid rotor that's pretty light.
MadScientistMatt
MadScientistMatt SuperDork
11/11/11 8:40 a.m.
If a mountain bike rotor isn't big enough, how about one off a low end sport bike like a GS500 or Ninja 250? They're fairly small, non-vented, and cross drilled, so they hardly weigh anything.
81cpcamaro
81cpcamaro Reader
11/11/11 8:43 a.m.
Motorcycle brakes would be a good, readily available choice. Another choice would be these: http://www.speedwaymotors.com/Sprint-and-Midget-Brakes.html but they do fail on the cost part, but excel in the light department.
logicfactory
11/11/11 8:57 a.m.
thank you for the responses. i should be able to get some weights later today.
the application will be a sub 1900lb street car that makes it to the drag strip a couple times a year, at best. i had prepared myself to spend the money with wilwood on aluminum hats and rotors but am now considering the topic of this thread as a compromise. if i can get some stock rotors within about 1.5lbs of what i was going to assemble i will likely abandon the wilwood brake project.
logicfactory
11/11/11 4:11 p.m.
the only rotor i was able to weight today were the fronts(vented) for a cx and vx; it weighed in at 9lbs and 9 ounces. i will try and get some more weights in the coming days.
mith612
mith612 Reader
11/11/11 4:41 p.m.
ditchdigger wrote: http://brembo.mycarparts.net/
According to Brembo, 1990 Miata rear rotors weigh 2.6kg (5.7 lbs) while 1992 Sentra 1.6 rears weigh 2.3kg (5.0 lbs) each. I don't think there is going to be a stock application rotor that is much lighter than that.
SVreX
SVreX SuperDork
11/11/11 5:09 p.m.
Seems to me there is an almost direct correlation between rotor weight and stopping power. Not quite, but almost.
Maybe not the primary target point for weight reduction on a race car.
logicfactory
11/11/11 6:09 p.m.
mith612 wrote:.
when i used that link the other day i never clicked on the part number and then the images to get a weight. thank you for the post and thank you ditchdigger for the link.
Run_Away
Run_Away GRM+ Memberand Reader
11/11/11 6:41 p.m.
Smart car? They used tiny non vented front rotors.
GHDxHzWdUFkGgexXrsmVrbXm1HLwdWSbNBVsD4sG0angjjJL7xPKCudWXshGgKa0
