4/27/10 3:38 p.m.
Sometimes it's the little successes that make the heart happy. Our 911 now has functioning headlights. As we figured, the culprit was the highbeam switch.
Replacing the switch itself wasn't too hard. It took just a few minutes to free the steering wheel, peel away the column's plastic covers, and remove the offending switch.
The trick came with connecting the …
grambo
grambo None
5/12/10 11:27 a.m.
Look into adding the headlight relay kit so this doesn't happen again. It's cheap insurance that you won't burn out another headlight stalk, and it also helps if you choose to run higher wattage headlamps in the future.
P64W6wXVG0mQj9RnQnAklRQbEZBJhNWc5sVwHdEYysbikhWjMhrhgkphKiRSoABE
