bluej (Forum Supporter)
bluej (Forum Supporter) UberDork
7/28/20 3:53 p.m.
This is for an MS (micro) 4cl wasted spark setup. I can use gm truck coils, or look into the marine version of ign1a's that's so cheap, but figured I should at least ask if anyone can reccomend a good, fairly priced, logic level triggerable dual output coil. The packaging might be better.
Paul_VR6 (Forum Supporter)
Paul_VR6 (Forum Supporter) Dork
7/28/20 5:51 p.m.
The vw coil for aeg (early 90s-00 4cyl beetle, golf, jetta) uses the same plug ends as LS and are two channel. Insert VW coil jokes here but they work well, pn should be in the microsquirt manual.
7/28/20 6:24 p.m.
Thanks for the rec, Paul!
o0q9jxLUwuScNgKL1OVdLtxN4TlbVR8oRih9rwgnr2uRNHNF9dWmznCPfzLk4cnH
