Mr_Asa
Mr_Asa PowerDork
6/23/22 10:03 a.m.
I'm waffling on how to approach this job.
Last week I found a $100 engine on FB Marketplace.  This week Pimpm3 picked it up for me, and it should be boarding the Stampie-train in the near future to make its way across the state.  (Thanks you guys, seriously.  I owe some beers.)
Why am I looking at doing another engine? Cause my old one went "berk you!" and E36 M3 the bed.  It was a bitch of a rebuild and getting it running and it seriously berkeleyed with my mental health when I couldn't get it running.
As a result of the pounding I took with the engine currently sucking down oil and gas at equal rates, I'm wary about how I should approach this one.
This one has 170k on it, apparently blew a headgasket.  I'll know more when it gets here and I can tear it down.  I'm wondering about how far I should tear it down and what I should do to build it back.
The head on my current engine is good and has a couple tweaks I want to keep (especially if it did actually blow a gasket) so I will likely just focus on the shortblock.  Provided there was no water in the cylinders, at 170k they should be good, I was thinking of checking the bores out with my gauges and such, if I pull the pistons I might dingle-ball the cylinders and throw new rings in it.
How far do I go, though?  I'm a little gunshy on just dropping my new head on and sending it.  I'm also a little gunshy about pulling it completely down.
Guidance, thoughts, even funny pictures would be appreciated.
untchabl
untchabl HalfDork
6/23/22 10:54 a.m.
Pull the head and look at the cylinder walls while the head is off. I typically replace all the gaskets on a replacement engine (minus the headgasket unless like in your case, the headgasket is known to be bad). While you have the oil pan off, you could pull a main/rod cap if you want to know but I personally wouldn't. If it was mine, if the visual inspection looked good, I'd slap your head on and run it.
Stampie
6/24/22 12:22 p.m.
Yeah I'd repair what was needed and not needlessly berk with anything. Do not follow my example in the C3 thread.
Tom1200
Tom1200 UltraDork
6/24/22 8:53 p.m.
I've taken good heads and bolted then to blocks in decent shape and run them.
jgrewe
jgrewe HalfDork
6/25/22 12:14 a.m.
I was on a team that ran the Longest Day at Nelson's Ledges back in the early 90's that started the race with a totally rebuilt engine in a CRX. Tons of details dealt with, lots of money spent for the pro rebuild. The engine lasted about 2 hours.
We scavenged a 150K mile short block out of the trailer, borrowed an old head and threw it together in the paddock.
The car finished the 24hr race and I think even ran a few events afterward with the $50 engine.
Do the seals, shake the rod caps and throw it together.
CrustyRedXpress
CrustyRedXpress GRM+ Memberand HalfDork
6/25/22 8:40 p.m.
No advice beyond what others have said, but don't get inside your head about the other engine. You're a competent guy and E36 M3 happens.
I didn't read all of the rebuild thread but I'd take extra precautions with the head gasket this time around if you swap the new/old head on this engine.
UU2ABd6HHsXekc4Z0HKNQjE6StDoNLmZRGCg1FYENUUTqpMMClOeelPlsPx6X1iU
