Im looking to drop an LSx into a solid chassis that either already does or can be made to handle well. Im looking for something that already has the swap kit (mounts) available.
Buddy of mine has a really nice S14 coupe that's getting the LS2/T56 treatment. Should be fun. I also know where there is a unused Sikky swap kit available for that installation, if you're interested.
How big of a chassis? You can make pretty much any RWD GM product from the mid 60s onward handle well without too much work, and the LSx bolts in with a set of gen 1 V8 mounts and a pair of adapter plates.
I know it's a dumb question. I've been trying to mull it over. F bodies are way over priced in my opinion. A decent one is around 8k where I am. I'd rather build something. I was thinking a light chassis 240 miata etc but I also want it cheap. Looks I could care less it will probably end up flat black.
How about an e31 BMW? Already have a rear end to handle v8 torque and e36 swap kits are probably pretty close to getting you there.
Plus, so sexy..
Kenny_McCormic wrote: How big of a chassis? You can make pretty much any RWD GM product from the mid 60s onward handle well without too much work, and the LSx bolts in with a set of gen 1 V8 mounts and a pair of adapter plates.
As long as you don't want A/C...
The two options to make A/C work is to move the passenger motor mount rearward (4"?), which is the best option IMO as long as it clears everything else, or to relocate the A/C compressor elsewhere, which tends to mean that it gets in everything else's way. The water pump design is somewhat limiting as far as accessory mounting is concerned.
icaneat50eggs wrote: z3/4 911 914 Exocet!!!!
The biggest problem with a 911 is that you can't get a cheap one anymore.
I think everone is missing the cheap part. Lol. Anyone strap one in a old mercedes? They are cheap and plentiful in the sub 1000 range. What about volvo 240s?
Both of those would be great projects and reasonably easy as swaps go, but I don't think anyone makes kits for either. JTR might have some of the parts for the Volvo, but not everything.
I've done a LOT of research into this. In order, your cheapest options are:
Swap LS1 back into an F-body
S10
944 turbo (supposedly the non turbo manuals aren't up to the torque)
240sx
calteg wrote: I've done a LOT of research into this. In order, your cheapest options are: Swap LS1 back into an F-body S10 944 turbo (supposedly the non turbo manuals aren't up to the torque) 240sx
Non-turbo transmissions after 87 are just as strong as the Turbo units.
The Turbo gearing is a bit better suited for the V8, but many swap early 5th gears into the turbo transaxle to get a better cruising gear.
