Trackmouse wrote: Greyhound just takes anything these days?!?!?
Greyhound Shipping said: The maximum weight per package is 100 pounds. The maximum dimensions that we can accommodate are 30" H x 47" W x 82" L.
http://www.shipgreyhound.com/e/Pages/faq.aspx#Ship_Q14
for cheap rx8 swap skip the eco boost motor and get a duratec found some as cheap as 250$ already pulled same bolt pattern can be turboed in stock form or built for n/a or big boost.....use nc transmission if you can weld aluminum modifying rx-7-8 trans bellhousing becomes an option as my cousin has a turbo2 mazda rotary box bolted to his turbo duratec in his lotus 7 clone just had to cut and move i think it was 2 bolt flange
I have a NC subframe, 5 spd trans, and 2.0 MZR in my garage.... I'm in STL, but can easily make it to Cincy with a truck full of parts.
Just in case you were needing some additional "motivation"
