poopshovel
poopshovel UltimaDork
3/15/13 1:32 p.m.
No, this is not the sequel to my critically acclaimed straight to DVD movie....
Anyway, similar issue to the trouble another member was having with his Escort. Car gets STUUUUUCK in 5th gear. Seems to be a non-issue if I pull it out of gear while approaching a stop light (which I typically do,) but if (for whatever reason) I don't get it out of gear before I stop, it takes a frightening amount of force to get it out of 5th.
Swap oil and say a prayer? I think the book recommends 10w-40.
M030
M030 HalfDork
3/15/13 1:59 p.m.
The title if this thread sounds dirty. I'm just sayin..
sachilles
sachilles SuperDork
3/15/13 2:14 p.m.
Have a look at the linkage underneath. I once jammed the linkage up with grass and such from borrowing my dads scort for a field party. Could not get it out of gear, and drove home in first gear.. Managed to catch grass up in there. I was able to clear it all before my dad needed the car returned. You probably won't be that lucky, but worth looking into.
aussiesmg
aussiesmg UltimaDork
3/15/13 3:19 p.m.
poopshovel wrote: "Moar Man Tranny trouble "
I freakn knew it.
Giant Purple Snorklewacker
3/15/13 3:23 p.m.
I did a quick google search on 'Man Tranny Trouble' from what I can tell I think you probably need more lube if it's getting stuck.
JohnRW1621
JohnRW1621 PowerDork
3/15/13 4:07 p.m.
Try pulling it in and out till it releases.
poopshovel
3/15/13 4:24 p.m.
Story of my life.
kb58
kb58 HalfDork
3/15/13 4:33 p.m.
Sounds like a disorder which requires a liberal application of some sort of ointment that comes with a tapered applicator...
jstand
jstand Reader
3/15/13 10:24 p.m.
Only fifth or any gear?
I've seen similar issues caused by a dragging clutch, either due to hydraulic issues or cable adjustment.
eebasist
eebasist Reader
3/15/13 10:55 p.m.
In reply to poopshovel:
I hear Astroglide makes a quality lubricant
crazycanadian
crazycanadian Reader
3/16/13 3:17 a.m.
How does your shifter feel? Its pretty common for the shifters bushings to wear out causing some shifter alignment problems..
is the linkage binding up on anything?
Could be a problem with 5th gear syncro or shift fork wearing out.. You can access 5th gear with out pulling the transmission.. Its behind the tin cover at the back..
poopshovel
3/16/13 7:15 a.m.
jstand wrote: Only fifth or any gear? I've seen similar issues caused by a dragging clutch, either due to hydraulic issues or cable adjustment.
Just 5th. Interesting. Shifter feels normal otherwise, but I'll check the linkage and maybe play with adjustment this weekend.
wbjones
wbjones UberDork
3/16/13 7:38 a.m.
probably no help to you ... just my curiosity .... when sitting/out of gear, can you then shift it into 5th and then back out again ?
3/16/13 7:58 a.m.
crazycanadian wrote: How does your shifter feel? Its pretty common for the shifters bushings to wear out causing some shifter alignment problems..
With all the silliness in this thread I read that as E36 M3ter the first time though.
poopshovel
3/16/13 9:36 a.m.
"Loose." Happens every time I drink tequila.
poopshovel
3/16/13 9:38 a.m.
So on the way in this morning, I did notice the shiFter might feel a little notchier than it once used to. Also, getting INTO 5th required a little more effort than normal a couple times. Thoughts?
Fueled by Caffeine
Fueled by Caffeine MegaDork
3/16/13 9:38 a.m.
I'll bet it has something to do with your motor mounts.
16vCorey
16vCorey PowerDork
3/16/13 9:55 a.m.
If linkage and mounts check out, I'd try changing oil. I've heard a lot of stories of crappy shifting that redline took care of. Lucas is good stuff too.
AngryCorvair
AngryCorvair GRM+ Memberand PowerDork
3/16/13 11:08 a.m.
Fueled by Caffeine wrote: I'll bet it has something to do with your motor mounts.
i'll take this one step further and say that the something is age/wear.
Spinout007
Spinout007 GRM+ Memberand SuperDork
3/16/13 12:30 p.m.
Glad I wasn't the only one.
poopshovel
3/17/13 6:12 p.m.
Interesting, as they are completely berkeleying shot.
Appleseed PowerDork
3/18/13 10:57 a.m.
Um...tuck?
EbyqdGjKIwZAMJQobr3YNOGT3YQ2aqMNYQOucuR4Qh1gTBcIgQSfmOB6GMY538rh
