Robbie
Robbie GRM+ Memberand PowerDork
12/21/17 12:13 p.m.
What about epoxy instead of welding? I'm talking the 3m stuff used to put structural aluminum sheets together.
dean1484
12/21/17 12:26 p.m.
Any heat or long term exposure to oil issues with that stuff????
Dusterbd13
Dusterbd13 MegaDork
12/21/17 12:49 p.m.
yes please. edumacate me. this sounds damn near perfect for a couple of things i need to do, thereby amortizing the cost.
Furious_E
Furious_E GRM+ Memberand SuperDork
12/21/17 2:05 p.m.
I busted a corner off of the oil pan on my LS1 (also cast aluminum) when I was installing a baffle last spring because I'm an idiot and missed a piece of old gasket before torquing it down. Since F body oil pans are apparently crazy expensive, I had a guy I know from work TIG it back together for me. Seems to be holding up just fine and doesn't leak or anything. I just cleaned the E36 M3 out of it with carb cleaner.
wvumtnbkr
12/21/17 2:07 p.m.
Just a reminder....  Dont weld after using the chlorinated carb cleaner.  It makes phosgene gas.
Bad.
Robbie
12/21/17 2:24 p.m.
One book I have suggests 3m scotch weld 9323 for joining aluminum honeycomb panels to make race car chassis, and mixing in something inert but of controlled diameter (like sand) so the joint stays tight without squeezing out all of the epoxy (optimal layer of epoxy is like .01 inch or something).
But I would think having more is ok for something less uniform than two pieces of sheet.
Furious_E
12/21/17 2:48 p.m.
In reply to wvumtnbkr :
Yes, should have specified non-chlorinated. I can't stand how bad the chlorinated stuff stinks anyway.
Dusterbd13
Dusterbd13 MegaDork
12/21/17 3:05 p.m.
How does it hold up to 250 degrees, oil, etc?
Robbie
12/21/17 3:23 p.m.
In reply to Dusterbd13 :
looks like it should be fine up to 150deg C.
https://www.google.com/url?sa=t&source=web&rct=j&url=https://www.3m.com/3M/en_NG/company-mea/all-3m-products/~/3M-Scotch-Weld-Epoxy-Adhesive-9323-B-A-1L-Kit-1%3FN%3D5002385%2B8709324%2B8709962%2B8710645%2B8710797%2B8711017%2B8711736%2B8712771%2B3292000134%26rt%3Drud&ved=0ahUKEwioxbX4hJzYAhWE1IMKHbpJCLMQFghcMAA&usg=AOvVaw0bjksFbvzUdxNKYUqtO4w7
Robbie
12/21/17 3:24 p.m.
Not sure the linking is working from my phone but Google pulls up the data sheet from 3m.
Dirtydog
Dirtydog GRM+ Memberand Reader
12/21/17 3:28 p.m.
How about asking your roll bar guru for a welding Christmas present?  Or  can you remove the offending 1 inch (no pun intended) from the crossmember and weld in some L channel?
NOHOME
NOHOME UltimaDork
12/21/17 3:34 p.m.
The side-bolts look way to far down to be main-cap cross bolts? What do they screw into?
stafford1500
stafford1500 GRM+ Memberand HalfDork
12/21/17 3:47 p.m.
My TIG is all tuned up and ready to go. Just finished fabricating a new aluminum oil pan for my project...
Dusterbd13
Dusterbd13 MegaDork
12/21/17 3:48 p.m.
This is step 1. But im looking ahead at ALL options, from easy to "what the berkeley am i thinking "
Nohome: dunno haven't pulled it, but from what ive read on the internet, they go to the mains.
Dusterbd13
Dusterbd13 MegaDork
12/21/17 3:49 p.m.
I actually got you a Christmas present today that isnt beer. But i can supply a six pack.....
stafford1500
12/21/17 3:54 p.m.
Sweet
jstand
jstand Dork
12/21/17 4:03 p.m.
tuna55 said:
jstand said:
oldopelguy said:
Welding aluminum is no big deal, but welding oil soaked aluminum is about as miserable as welding can get. If you can start out with a brand new pan you will have much better results for both strength and leakage.
If you can't go new (or even if you do go new), try to find someone with an industrial oven that can bake it for several hours to try to remove as much of the oil as possible.
When I worked for a company that instrumented engine components, the first step was always to bake the parts (new or used) to get rid of any oils in the metal so adhesives would bond reliably.
Indeed my materials guy suggested baking it at low temperatures, he said 400F for four hours, then weld. It worked for my bellhousing.
We always tried to bake it hotter than the cure temp for the adhesive, but the 400 degree range was typical. The bake was dependent on the part, how dirty it was, if it was used, and the material.
We would clean it with IPA or other cleaner, wipe it down, bake, then clean and wipe. We’d repeat the process until the wipe down didn’t have any more oil on the cleaning rag.
wvumtnbkr
12/21/17 4:05 p.m.
They do go in the area of the mains.  It's a little weird.
Opti
Opti HalfDork
12/21/17 4:33 p.m.
What 3.4 is this and does it vary from the fbody 3.4. Im pretty sire the fbodys use a steel pan
dean1484
12/21/17 4:41 p.m.
dean1484 said:
I say go for it.  Just put back the same thickness of material in the areas that are modified.  Get sone one that has some experience with welding aluminum and I would not worry about it.  The only issue I would have is if it is cast alu and not sheet.  That may be an issue with respect to welding.  Better look in to that before you start cutting.  One of my guys at work is a licensed welder and he would know the answer.  I will ask him tomorrow and report back.
Spoke to my employee and he said no problem.  Started mumbling about cleaning it really good etc but basically not a problem. Pre heating the pieces makes it easier to weld.
Dusterbd13
Dusterbd13 MegaDork
12/21/17 4:54 p.m.
In reply to dean1484 :
Thank you, and thank him for me
Everyone else: y'all are the reason why this is the only forum/social outlet i go to. Thank you all. Its definitely appreciated.
Opti: fwd 3400 is radically different from the rwd 3.4 no way to interchange much of anything.
GTXVette
GTXVette Dork
12/21/17 5:39 p.m.
 My rwd block pan looks kinda SBCish and would fit No Problimo,  My engine kinda Hangs in space so I could rock that Pan you have, 90% finished on rebuild. rainy cold day's make me want to stay inside, so maybe Tomorrow / Saturday we'll give her a Spin.
Dusterbd13
Dusterbd13 MegaDork
12/21/17 6:10 p.m.
In reply to GTXVette :
i had looked at that, as the rwd pans are readily available. bolt pattern is different, as well as no way for the cross bolted mains. so, thanks for the offer but i cant realistically make it work with the tools and talent that i have access to.
Crackers
Crackers Dork
12/21/17 8:22 p.m.
A mapp torch will work to burn off the oil.
A mapp torch will work to turn it into a puddle too.
In fact, you can "weld" aluminum with a mapp torch.
I once cut 2 2.8l timing covers in half and "welded" them back together with an O/A torch and AL rods from TSC.
Although, I don't recommend doing so without practice.
I have a package of that HF "Alumaweld" that I've been wanting to play with, but I bet that stuff would work for this too.
Crackers
Crackers Dork
12/21/17 8:37 p.m.
If you do use a mapp torch the safe bet is drawing a line with a 400° temp-stick (actually, one at the edge and one and inch or so back) and heat from the back side slowly.
Keep the torch moving across the whole area to avoid hot spots and you should be fine.
Alternatively, you could scan it occasionally with an IR thermometer.
Much over 400° and you're flirting with aluminum's plastic state, and you don't want that.
When heating aluminum for forging processes, it goes from ideal forging temperature to molten within seconds, so be careful.
G1MGi6POyPCZ8dfMAHbDboBrFa0teoNmbDRM2by9fnHauxAmw8TpPJ9y7HqS9QB7
