dansxr2
dansxr2 HalfDork
2/23/12 7:48 a.m.
Will they interchange? Replacing the front and rears as my driverside rear has some play... I know the swaybar mounts differ, can anyone confirm interchange?
ST_ZX2
ST_ZX2 HalfDork
2/23/12 7:54 a.m.
I believe so--they should interchange.
92CelicaHalfTrac
92CelicaHalfTrac SuperDork
2/23/12 8:28 a.m.
I know the ZX2s interchange with the EGT, and i'm 90% sure that the only difference between MX3 arms and EGT arms is length. Attachment points and sizes are all the same i'm PRETTY sure.
dansxr2
dansxr2 HalfDork
2/23/12 8:42 a.m.
Its the rear trailing arm bushings in particular that's bad in mine. My right trailing arm has some cancer on it, would it possibly interchange with anything?
92CelicaHalfTrac
2/23/12 8:51 a.m.
dansxr2 wrote: Its the rear trailing arm bushings in particular that's bad in mine. My right trailing arm has some cancer on it, would it possibly interchange with anything?
It might actually interchange with the ZX2 trailing arm. They're tubular and a bit stronger. I have a modified pair for my EGT.
The MX3 is a wider track than the ZX2, but i don't think it's any "longer" North/South.
If you wanna go down the rabbit hole.... All the suspension arms i'm using on my car will work on yours.
http://www.piercemotorsport.com/servlet/Categories?category=91-96+Ford+Escort%3ASuspension
He doesn't have the fronts listed, but he typically makes them to MX3 specs anyways.
sTcUYzTa9HYV9lkmbd1SDMX7QDYs0iILNCMYOdlPnuLYuphXnatoHFF9UsIfAu8g
