petegossett
petegossett GRM+ Memberand Dork
11/26/08 10:36 p.m.
My Sidekick isn't heating up very well. The t-stat & cap are new, I let it idle for 1/2-hour tonight w/the cap off to get any air out, then took it for a drive - the gauge barely moves off the "C" mark & I barely get any heat out the vents. Driving speed/idle/etc. make no diference.
I did notice the fan is always turning whenever the engine is on. I checked & I can spin the fan by hand, but not very freely. It's been years since I've owned anything with a mechanical fan, does it sound like the fan clutch may be bad? I'm running out of ideas for what could be causing this. The truck runs/drives fine otherwise.
porksboy
porksboy HalfDork
11/26/08 10:52 p.m.
double check the T-stat in a pan of water on the stove. Put a thermometer in the water to verify when it opens. Look at the T-stat to make shure it is not stuck open. Do the hoses stay cool to the touch? If not you may have a bad guage/ sending unit.
iceracer
iceracer Reader
11/27/08 11:30 a.m.
Sounds as if your fan is normal. As porkboy said, test the thermostat. There are some really crappy stats available.
CsYXpovw0vLrFe3nbhhrnt6W8JuISQdcRsZcMXfjDOxfvo2S4PV2zNZkzTGrfssV
