AClockworkGarage
AClockworkGarage HalfDork
7/22/17 7:54 p.m.
The top one is a 3/8 NPT to -6 AN adapter. The bottom is the old hard line that came out of my fuel pump... they are not the same. Both of them thread into a 3/8 brass fitting I found at a hardwaqre store, but the blue one will not fit into the pump.
What do I have here and where can I find an adapter from that to -6 AN?
stuart in mn
stuart in mn UltimaDork
7/22/17 7:56 p.m.
The bottom one looks like the threads are worn out - maybe it started life like the top one?
edit: Is the top one really NPT threads? Now that I look at it again the threads look too straight for that.
mikeatrpi
mikeatrpi HalfDork
7/22/17 8:04 p.m.
It looks like the hard line had a flare. They make AN to inverted flare fittings:
https://www.summitracing.com/parts/rus-640380/overview/
AClockworkGarage
7/22/17 8:06 p.m.
https://www.summitracing.com/parts/aer-fbm2005
That's the top one, and it doesn't fit.
dean1484
7/22/17 8:14 p.m.
Metric flair???
dean1484
7/22/17 8:15 p.m.
When this happens to me I go to the local parts store and go in the back and start trying things.
BrokenYugo
BrokenYugo MegaDork
7/22/17 8:31 p.m.
Bottom one looks like a straight thread inverted flare nut, not NPT. If you don't have thread gauges and a dial caliper to figure out what thread you have you could take it to the hardware store/home depot/tractor supply and figure it out with their board of bolts and nuts thread checker.
Trackmouse
Trackmouse SuperDork
7/23/17 1:38 a.m.
What kinda application? My Toyota had this. (I'm told all Toyota have m14x1.5 inverted flare fuel fittings)
slowcamaro
slowcamaro New Reader
7/23/17 6:16 a.m.
Camaro mechanical pump? If so rock auto says "Outlet Size 5/8-18 UNF"
Knurled
7/23/17 7:46 a.m.
Agreeing with above - not an NPT fitting, you can see the tube flare under the tube nut.
dean1484
7/23/17 7:54 a.m.
Now that I have looked at this on my PC screen that definitely is a flair fitting. You can see both the flared end of the tube in the fitting and the threads are strait not tapered like the one above it.
8bkuYTSyjk9CXOzBl1PbwUfschd7LCxdcJATa4APIP8xNZiX5t6UhYSoN8KEVeyn
