1 ... 10 11 12 13
oldeskewltoy
oldeskewltoy UberDork
2/13/24 10:26 a.m.
Hmmmmm, one of my shop mates recommended these......  available 4 x 114.3, but only one size 15 x 7 with an offset of 6.95mm - spinner optional
w/o spinner
oldeskewltoy
2/15/24 5:13 p.m.
Pretty significant view/moment.....  The drivetrain being fully supported by the car.  No jacks, or stand.   Yes, the cross member needs to be welded up,, and yes the "Trans mount" is a piece of wood wrapped in a box for now, but for transport purposes it should be more then adequate.
more to come......
2/15/24 5:17 p.m.
In reply to oldeskewltoy :
Hell yeah, man, that's a big moment!  Congratulations!
oldeskewltoy
2/18/24 10:53 a.m.
on the wheels....  might have to revisit the springs as she is riding high, and firm.
ae86andkp61 (Forum Supporter)
ae86andkp61 (Forum Supporter) GRM+ Memberand SuperDork
2/18/24 12:17 p.m.
I was thinking last night that we should measure the aftermarket springs on the car (at least for diameter of the wire) and measure the stock springs off the car for diameter, free length, and number of coils. Count the coils on the aftermarket springs, guesstimate the free length based on older photos of the springs side-by-side, and do some calculating.
Something is wrong. I have a really, really hard time imagining the aftermarket springs are 10% stiffer and 1/2" shorter than stock, given how high the car is riding, and given that it felt fairly stiff when bouncing on the fenders yesterday. I doubt the added weight of glass, fluids, paint, and interior will cause it to settle that much.
Before having the springs remade, probably worth investigating and confirming the specs.
oldeskewltoy
2/24/24 11:31 a.m.
on to the next chapter......
needless to say........
more to come....smiley
2/24/24 12:12 p.m.
In reply to ae86andkp61 (Forum Supporter) :
I wouldn't worry about it too much until the car is assembled and at its full weight. There is a lot missing from the car right now and it will sit lower as you put it back together.
The springs may settle a bit, too.  We used to say drive a car for a thousand miles before doing a proper alignment, when we replaced the springs on B and G body GMs.  They would drop an inch or two from settling.
DarkMonohue
DarkMonohue GRM+ Memberand Dork
2/24/24 5:27 p.m.
It might not hurt to loosen the control arm bolts roll the car back and forth several times and give it a few good bounces in between. If those bolts get tightened when the suspension is extended, it will tend to return to that position.
oldeskewltoy
2/25/24 9:34 p.m.
the parts car is just about ready to follow....
2/25/24 11:26 p.m.
In reply to DarkMonohue :
Thanks for the tip. We did drop it on the ground and bounce a little before tightening suspension fasteners. The engine was in up front, and oldeskewltoy stood in the trunk while I did the rear arms and panhard. We will have everything loose and bounce again once it is more assembled and closer to final weight.
oldeskewltoy
3/3/24 1:23 p.m.
so the donor is ready to follow.   3 tires that hold air, with one that holds air for a day, or 2.
The hood had to come off because those hinges were nearly seized - it took 3 of us to get it open from about a foot to where it was in previous post, it wasn't going back down....
... and some ingenuity to keep the rotted trunk lid from flying away.
more to come.....
oldeskewltoy
3/14/24 4:25 p.m.
The donor on the way...
more to come....
oldeskewltoy
3/22/24 10:19 a.m.
oldeskewltoy
3/23/24 10:49 a.m.
oldeskewltoy
4/13/24 7:30 p.m.
Donor on to it's new owner......  yep a fellow Mark II owner will strip it further.......
oldeskewltoy
5/1/24 10:54 a.m.
sound deadener removed..........  floors are pretty good - especially for a Japanese car from 1972 surprise
 Driver side is a bit worse.  Passenger side is in very good nick
Note: bottom left - rubber drain plug still installed
More to come....... smiley
oldeskewltoy
6/28/24 12:52 p.m.
fixing the hole in the driverside floor.........
A bit of progress.......
oldeskewltoy
9/12/24 1:57 p.m.
Just makes more sense to post up the Facebook link............
https://www.facebook.com/share/p/ktsS3CxcuTrw4tkS/
but here are some highlights so far.....
passenger door....
driverside...
more to come....
Recon1342
Recon1342 UltraDork
9/13/24 11:11 a.m.
Whoohooo!!!
oldeskewltoy
9/15/24 12:48 p.m.
and some low lights.... driverside rear quarter.......  stitched together photo showing a previous crappy repair, and even further damage
more to come......
oldeskewltoy
9/16/24 12:03 p.m.
making room......
more to come....
oldeskewltoy
9/17/24 7:41 p.m.
Driverside fender...  rust on the inside.........
and after the inside was solid, they fixed the outside
oldeskewltoy
9/20/24 6:27 p.m.
Making room when finished these open convex sections will be replaced with a concave section providing enough room for a tapered log type manifold - just insufficient room for something multi - tubular.
9/20/24 6:49 p.m.
more to come......
This was the biggest moment for "Colin", even bigger than when it sat on four wheels for the first time.
oldeskewltoy
9/24/24 11:14 a.m.
Now that there is room.........
stainless steel header parts
Driver side....
initial fitment
more to come...... smiley
1 ... 10 11 12 13
0znUJBzJxqlxukYslz3PnRFgN6ZhnVnDtUn0yDmO3vGAJ2Y21NXAknfBvONkF76i
