Countingcrowbars
Countingcrowbars UltraDork
7/12/21 7:01 p.m.
I've read the door bushings are the same regardless of chassis. I 3D printed some beautiful abs door bushings and the door won't close. Is the internet right about all Miata door bushings fitting all Miata? Is there any install tips?
Countingcrowbars
7/12/21 7:10 p.m.
ok I got the door to close but had to slot the new door bushings with a drill. Apparently they pushed out too far to allow the door to close.
Daylan C
Daylan C PowerDork
7/12/21 7:26 p.m.
Yeah the FM bushings have a bit of adjustment to them and my passenger door is a bit iffy to close now because I got that one off a bit and never went back to fix it. (100% my error installing them to be clear)
Countingcrowbars
7/12/21 7:31 p.m.
In reply to Daylan C :
And for reference, these aren't FM door bushings. This is my own home brew 3D print. Thus I ask the living Miata encyclopedia.
7/12/21 7:31 p.m.
It's possible to design a bushing that fits all Miatas, but a bit of on-car adjustment is sometimes required. I've never tracked down the specific cause, probably slight differences in door alignment.
Daylan C
Daylan C PowerDork
7/12/21 11:54 p.m.
In reply to Countingcrowbars :
I didn't meant to imply those were FM bushings. I just said the FM bushings seem to be designed with the same fix you ended up finding yourself.
U669NLtmkWHJljAGxmi8Y2sNtAbZYFL0XFmYRkIzy570EBzrhZP4FfquE5kKBQOA
