1 2 3 4
wearymicrobe
wearymicrobe Dork
4/30/14 1:46 p.m.
I am sure that we have hashed this out but I feel the need to do it again. In terms of DD where do we sit as a group. The wife's Mini is out of warranty and being sold this weekend (Pending check clear). She is taking the Subaru, and my father is getting my mustang leaving me for once with a completely clear slate and a actual garage space and a pile of cash.
I need a do literately everything DD. Autocross and driver training three-four times a year, going to work in traffic 365, can be driven in the rain. Must be comfortable enough that I can drive from SD to Las Vegas at least 3-4 times a year and sit in LA traffic without cooking me alive. I am not flipping cars really at this point so no weekend car hence the big budget.
Plaid speed
2010 911 Turbo S PDK.
Ballistic
2008 911 Turbo Cab Manual
Fast
R8 V8 (Basically the best all rounder I have found, but no fizz)
911 S 10' PDK
Slowish
Bite the bullet and get 2015 Vantage GT
Outlier
Bentley Spur SS (I can get these cheap, clearly can not be driven on the track)
Used CTS-V Manual wagon
E63 AMG Wagon
4/30/14 1:53 p.m.
Maybe you should throw an Evora in there...
Edit: And maybe a Jag F-type?
wvumtnbkr
wvumtnbkr GRM+ Memberand Dork
4/30/14 1:56 p.m.
New CTS V wagon?
New ATS V?
Thats all I could add to the list.
However, I always hear that if you want an everyday car, get a Porsche.
Rob R.
Swank Force One
Swank Force One MegaDork
4/30/14 1:57 p.m.
Plaid. ALWAYS go plaid.
4/30/14 1:58 p.m.
Imagine the kind of modded ZR1 you could buy with R8 money and the running costs would be the lowest of them all...
Edit: D'oh actually they're pretty close. But remember: Sane parts costs.
92dxman
92dxman Dork
4/30/14 1:58 p.m.
I'd go for the CTS-V Wagon. That has a cool factor and screams do it all car to me the most from that list.
wearymicrobe
wearymicrobe Dork
4/30/14 2:01 p.m.
GameboyRMH wrote: Maybe you should throw an Evora in there... Edit: And maybe a Jag F-type?
The local dealers are total E36 M3. It part of the reason I have not bought a Aston/Lotus/Jag in the past locally. They had exactly what I wanted in stock, went in to test drive and they treated me like just below them, feet on the desk sort of thing, fake Panerai 88 on each of theirs wrists. I actually went into the sales managers officer and pulled out a bank statement, that I brought as income verification, popped it on his deck and told he exactly where he could stick his sales staff.
fidelity101
fidelity101 Dork
4/30/14 2:12 p.m.
new M5?
wearymicrobe
wearymicrobe Dork
4/30/14 2:14 p.m.
fidelity101 wrote: new M5?
To common out here honestly and BMW's and I in the past do not get along to well. To much tech in the cabin which turns me off a bit.
I wish the corvette had a bit more storage and a bit better build construction.
93EXCivic
93EXCivic MegaDork
4/30/14 2:20 p.m.
Morgan Aero 8?
http://www.hemmings.com/classifieds/dealer/morgan/aero_8/1634187.html
Probably best bet for holding value.
codrus
codrus GRM+ Memberand HalfDork
4/30/14 2:55 p.m.
GT3
Jarod
Jarod GRM+ Memberand Reader
4/30/14 2:55 p.m.
911 Turbo coupe.
captdownshift
captdownshift GRM+ Memberand HalfDork
4/30/14 2:57 p.m.
volvo 240 wagon, 9:1 aluminator and twin EFR6758's
http://www.turbos.bwauto.com/aftermarket/matchbot/index.html#version=1.3&displacement=5&CID=305.1&altitude=500&baro=14.502&aat=75&turboconfig=2&compressor=67x80&pt1_rpm=2000&pt1_ve=85&pt1_boost=5&pt1_ie=99&pt1_filres=0.08&pt1_ipd=0.2&pt1_mbp=0.5&pt1_ce=60&pt1_te=75&pt1_egt=1550&pt1_ter=1.21&pt1_pw=5.99&pt1_bsfc=0.43&pt1_afr=11.5&pt1_wts=300&pt1_wd=83&pt1_wd2=74&pt1_wrsin=69033&pt2_rpm=3000&pt2_ve=95&pt2_boost=12&pt2_ie=95&pt2_filres=0.1&pt2_ipd=0.2&pt2_mbp=1&pt2_ce=68&pt2_te=73&pt2_egt=1600&pt2_ter=1.51&pt2_pw=16.94&pt2_bsfc=0.45&pt2_afr=11.5&pt2_wts=320&pt2_wd=83&pt2_wd2=74&pt2_wrsin=73635&pt3_rpm=4000&pt3_ve=100&pt3_boost=14&pt3_ie=95&pt3_filres=0.12&pt3_ipd=0.3&pt3_mbp=1.3&pt3_ce=72&pt3_te=72&pt3_egt=1650&pt3_ter=1.69&pt3_pw=30.72&pt3_bsfc=0.48&pt3_afr=11.5&pt3_wts=340&pt3_wd=83&pt3_wd2=74&pt3_wrsin=78238&pt4_rpm=5000&pt4_ve=100&pt4_boost=14&pt4_ie=92&pt4_filres=0.15&pt4_ipd=0.4&pt4_mbp=1.5&pt4_ce=74&pt4_te=71&pt4_egt=1650&pt4_ter=1.8&pt4_pw=37.95&pt4_bsfc=0.5&pt4_afr=11.5&pt4_wts=368&pt4_wd=83&pt4_wd2=74&pt4_wrsin=84681&pt5_rpm=6000&pt5_ve=105&pt5_boost=14&pt5_ie=90&pt5_filres=0.18&pt5_ipd=0.5&pt5_mbp=1.8&pt5_ce=64&pt5_te=70&pt5_egt=1650&pt5_ter=2.06&pt5_pw=39.3&pt5_bsfc=0.52&pt5_afr=11.5&pt5_wts=400&pt5_wd=83&pt5_wd2=74&pt5_wrsin=92044&pt6_rpm=7000&pt6_ve=105&pt6_boost=10&pt6_ie=90&pt6_filres=0.2&pt6_ipd=0.6&pt6_mbp=2&pt6_ce=60&pt6_te=70&pt6_egt=1650&pt6_ter=1.92&pt6_pw=44.47&pt6_bsfc=0.55&pt6_afr=11.5&pt6_wts=400&pt6_wd=83&pt6_wd2=74&pt6_wrsin=92&
mazdeuce
mazdeuce UltraDork
4/30/14 3:02 p.m.
Keep in mind that the V wagon is really a seven year old car at the end of it's run. Nothing about the chassis or motor are even a tiny bit bad, but the interior and especially the radio/electronics aren't modern. We've moved beyond the idea that one should load music onto the cars hard drive via your CD collection.
Slightly less than 400 miles into mine and it's absolutely the right choice for me, but it's something to think about.
wearymicrobe
wearymicrobe Dork
4/30/14 3:29 p.m.
mazdeuce wrote: Keep in mind that the V wagon is really a seven year old car at the end of it's run. Nothing about the chassis or motor are even a tiny bit bad, but the interior and especially the radio/electronics aren't modern. We've moved beyond the idea that one should load music onto the cars hard drive via your CD collection. Slightly less than 400 miles into mine and it's absolutely the right choice for me, but it's something to think about.
I test drove one, its not going to work unless I get a used one with some modifications to make it a bit more modern. Also the back seat is surprisingly small and the hatch slopes down so aggressively I was surprised that you could get the tuba in.
Adrian_Thompson
Adrian_Thompson PowerDork
4/30/14 3:34 p.m.
I'd love to be able to add something cool you haven't thought of to the list, but I can't see anything better than a 911 Turbo S or an R8. For the money of a 2010 Turbo S can't you get into an early V10 R8?
wearymicrobe wrote: The local dealers are total E36 M3. It part of the reason I have not bought a Aston/Lotus/Jag in the past locally. They had exactly what I wanted in stock, went in to test drive and they treated me like just below them, feet on the desk sort of thing, fake Panerai 88 on each of theirs wrists. I actually went into the sales managers officer and pulled out a bank statement, that I brought as income verification, popped it on his deck and told he exactly where he could stick his sales staff.
Wish I could have seen his reaction, and the sales guys when he ripped them a new one. Didn't the Manager beg forgiveness and offer his first born in an effort to win you back?
Flight Service
Flight Service MegaDork
4/30/14 3:35 p.m.
I would love to find a 911 GTS PDK Sport Chrono...I found one but it was a Cab.
Jeff
Jeff SuperDork
4/30/14 3:38 p.m.
I vote plaid; but I confess to wanting to get a long term PDK enthusiast perspective.
mfennell
mfennell Reader
4/30/14 3:49 p.m.
Turbo S given that list but by my count you had 3 cars until recently. Was that too many? From my (possibly warped) perspective, the tire/fuel budget of daily driving a Turbo S could damn near pay for a simple/comfortable/more spacious DD and let you get crazier with a limited use sports car. It looks like 997 Turbo S money gets a clean F430 or Gallardo if you like those things.
T.J.
T.J. PowerDork
4/30/14 3:49 p.m.
I always like the microbe threads. I have no idea of which of those you should buy. I'd like any of them as long as I didn't have to pay for them, but I have no idea of which I think I would like the best.
Interesting insight on the CTS-V.
What about the Morgan? If an M5 is to common to consider, then I doubt that the Aero8 would be too common. Not sure about availability and price, but that would be the one I would want to experience to see if it would work for me, then I would start down your list of the usual suspects.
mazdeuce
mazdeuce UltraDork
4/30/14 3:51 p.m.
Everything you say is correct, but I still love it. I have to admit, if I didn't already have a 911 that I love, I might have shopped differently.
captdownshift
4/30/14 3:55 p.m.
on a serious note, if looks don't matter panameria is the answer
Maroon92
Maroon92 MegaDork
4/30/14 4:05 p.m.
For real, the 911 Turbo will do everything anyone would ever need in a car. It is ballistic quick, but it's easy to drive around town.
I would not buy an R8 V8, because that is a lot of money for something that is slower than a Boxster S.
mfennell
mfennell Reader
4/30/14 4:07 p.m.
captdownshift wrote: on a serious note, if looks don't matter panameria is the answer
I test drove a 4S (IIRC) and was in a GTS that my friend test drove later. Call us shallow but there was just way to get past the ugly. That, and our uniformly miserable experience with service at our local dealer turned us (personally) off from P-cars.
4/30/14 5:48 p.m.
I realize slower than some of your cars.. what about the Cayman S?
1 2 3 4
FGlIcg4xRAI8Oe3Gb9o5LhZEC6YVP1GaLRMhb86O6qErB48uwHozQmDh1SzWU1Uw
