Grtechguy
Grtechguy MegaDork
6/26/23 4:17 p.m.
My truck started giving a misfire while pulling our camper.
The code scanner showed  Cylinder 6 miss fire as the only code in memory.   at 75K on the plugs I figure I had a few more miles, but replacing plugs is far cheaper than coil packs.
What do you guys think of the condition of these?  Cylinder 6 should be drivers rear (Bottom Left) if I'm reading the literature correctly.
Toyman!
6/26/23 4:52 p.m.
In reply to Grtechguy :
What engine. If Ford with cop, the plugs will outlast the coils.
And I would say 6 has been misfiring.
Grtechguy
Grtechguy MegaDork
6/26/23 4:58 p.m.
2nd gen EcoBoost 2.7
alfadriver
alfadriver MegaDork
6/26/23 5:04 p.m.
To me, the plugs look normal.
One thing that has been a problem is water in the intercooler- any chance you can pop a hole in it and plug it with a screw?
IIRC, I've seen postings here of a pin hole drill that doesn't leak enough to cause a power problem.
bumpsteer
bumpsteer Reader
6/26/23 5:05 p.m.
This aligns with my experiences with Fords and coil failure.
Grtechguy
Grtechguy MegaDork
6/28/23 2:56 p.m.
thankfully it was just the plugs.   Even though the parts store sold me a cracked plug that took me some time to figure out.
Overthought things and was swapping coils and regapping the plugs before taking a closer inspection.
JByasit9kPjLbeZmonxFDU8fZAIDWmDEqoE9yVFDYWjsQuSEiaFXpGMFPmffJCWc
