ae86andkp61
ae86andkp61 GRM+ Memberand Reader
9/14/09 4:17 a.m.
For those not following along on my Reader's Ride page, I have a RWD Corolla and I am working on a mild-to-medium-built 4A-G to replace the mostly stock 4A-G in there now. I will be running FJO 341B engine management, which comes with an oil temperature sensor.
I will be using the sensor to A) output to a guage in the car, and B) send the ECU into a limp mode if the oil temp exceeds certain parameters. I also have an oil cooler and a Mocal thermostatic sandwich plate, so hopefully (knock on wood) none of this will ever be an issue, it is all just a nice reassurance for me while driving hard.
I guess the sensor typically goes in a weld-in bung in the oil pan, but my pan is already on and buttoned up. I really don't feel like pulling off the pan (which also requires pulling off the pickup and the windage tray) and then cleaning off all of the FIPG I already put on there, getting a bare spot through the new powdercoat, welding in a bung, and having the pan re-powdercoated, new pickup gaskets, new FIPG, torque all twenty-something fasteners, etc. I also don't fancy drilling and/or welding on a sump mounted to a fresh bottom end.
My buddy has a very similar build and the same issue with the sump. He put his sensor in a tee on inner fender, like this:
My plumbing at the sandwich plate is a bit stouter and a bit simpler, so I have entertained the thought of trying to mount the sensor inline right where the hose comes out of the sandwich plate. Here is where I would be attaching the fitting:
But I am worried about the weight and the vibration. The fittings in there now are steel. I won't do brass (heavy and brittle) but it seems like the fatigue resistance of aluminum isn't great, and the weight of steel is a lot to cantilever out there.
The appeal is just keeping the lines to the cooler shorter and more direct, and also keeping the wiring harness shorter and tidier, rather than running all the way to the outside of the engine bay.
Am I asking for trouble? Any thoughts or practical advice?
Armitage
Armitage Reader
9/14/09 8:34 a.m.
You could remove the sandwich plate, drill and tap the back side and install the sender directly in there.
porksboy
porksboy Dork
9/14/09 8:45 a.m.
More Grassroots/ ghetto would be fashion a probe with wires on the end of the dipstick.
Dashpot
Dashpot New Reader
9/14/09 9:17 a.m.
In reply to ae86andkp61:
I suggest a tee fitting (F-AN x F-AN x 1/4" FNPT) and install the sender at either end of the oil outlet hose, upstream of the oil cooler inlet.
ae86andkp61
9/15/09 10:03 a.m.
Dashpot wrote: I suggest a tee fitting (F-AN x F-AN x 1/4" FNPT) and install the sender at either end of the oil outlet hose, upstream of the oil cooler inlet.
Thanks for the thought...this was my plan, but the real question is: can I safely mount the tee at the engine block end of the outlet hose, or will the vibration be too much for it?
Also, is anyone aware of a female tee fitting -10 AN x -10AN x 3/8"NPT? I've been searching everywhere with no luck. I can find tons of options for -8 AN, but the lines, cooler, fittings, etc. that I already have are -10 so I would like to use them if possible.
Hj0ArkFkoXYGF5hn6PkVCxvboEr405VYw8HtSd7ucZj4HkXyHb70fKYHy03zNca8
