OK looking at cheap CL 996's what on earth would cause this much movement in the crank? I am assuming the motor and case are TOAST at this point....
z31maniac said:I think it's safe to say that is trashed. :)
Agreed, case too most likely is my guess, but I am no Porsche expert....
Duh, everyone knows it's the throwout bearing that holds the crank in on a P car. Put the tranny back in and it will be fine I'm sure. Who's idea was it to run the engine that way? Some peoples kids, I tell ya.
Now if you see the other end of the crank doing that, you have problems.
In reply to akylekoz :
/sarcasm tag missing?
Seller was trying to find issue.... Took video to show to people looking to buy car.... Hes fully open to having some rather massive issue.
What might have caused this?! Seems like way more play than should be there even is the bearings are completely gone.
Vw bugs sometimes broke the crank in half , so it would still run but you could pull the front pulley and have more than a quarter inch play ..
californiamilleghia said:Vw bugs sometimes broke the crank in half , so it would still run but you could pull the front pulley and have more than a quarter inch play ..
Yeah I have seen that before!
I think its is a differen't issue, just not familiar wiht Pcars
I would be curious to take a look at the IMS Bearing. If that movement is the crank and not just the flywheel, that should be leaking oil like a sieve.
I'd be worried that the crank cradle is damaged - which requires a complete strip down of the engine to get at.
BoxheadTim said:I'd be worried that the crank cradle is damaged - which requires a complete strip down of the engine to get at.
I'm pretty sure the engine is garbage at this point....
One time on my old VW I discovered 1/4" play in the crank. Didn't leak more than normal, and ran just fine. That engine was mostly a porsche. I rebuilt it anyway. I'd say the car in the video is probably still faster than my old VW. Doesn't mean it isn't borked.
I see a flywheel jumping around. Wouldn't be the first one to come loose. Without digging deeper it's not possible to make further assessments.
That’s a 996 roller and worth 5k at most.
The engines cost more to rebuild than a complete running well cared for car costs.
java230 said:....but I am no Porsche expert....
I bet you will be pretty soon. So where do i find the build thread?
gearheadmb said:java230 said:....but I am no Porsche expert....
Well my dad beat me too it, so we will see. He doesn't have a plan yet.
AnthonyGS said:That’s a 996 roller and worth 5k at most.
Yep and a 54k mile car....
