Floating Doc (Forum Supporter) GRM+ Memberand PowerDork
11/1/21 11:35 a.m.
We don't deal with the same weather extremes of cold, ice, etc. here in FL, but the sun and heat really take a toll.
What's your experience/recommendations?
Ranger50
Ranger50 MegaDork
11/1/21 11:37 a.m.
$3.99 blades from rural king. I haven't found a decent reason to spend more money for something I'd change at the same rate.
No Time
No Time SuperDork
11/1/21 11:44 a.m.
Depends on the vehicle.
If the blade is 24" or less I liked the Bosch Icon blades. If longer than that I found beam style blades flexed too much.
On the longer sizes I like the rain-x with the traditional exposed metal frame or a Michelin. Hybrid with the covered frame (like a winter blade).
11/1/21 12:15 p.m.
It rains so little and the sun is so strong around here that they're almost one-time use. So I just carry a spare set of ANCO cheapies in any vehicle that is doing a road trip, because invariably the wipers will turn out to have perished when it starts to rain.
John Welsh
John Welsh Mod Squad
11/1/21 12:24 p.m.
Yes, Rural Kings too, but...
Menards is often my go-to to for wiper blades.  They commonly have a house brand for $0.99 pre blade.  At that price, I tend to keep a fresh replacement blade in the spare tire well.  My blades are easy to change out (no tools required) so I have a fresh set with me if I have an unexpected failure.
Edit: I figured I'd check Menard's wbesite:
$0.99 for 3 common sizes
$2.99 for 10 sizes
$4.99 beam style
Also, in the spring look for close-out prices on "winter blades."
I also commonly buy blades 1 to 2" longer than "correct size"  This then equates to 1/2" to 1" longer on each side of the blade.  I have not had a car yet that couldn't accommodate the additional length.  Usually, there is no price increase to get the larger.  So, free size increase.
bobzilla
bobzilla MegaDork
11/1/21 12:38 p.m.
I still believe that honda blades and inserts are the best value to life ratio. I could easily get a year out of a set of honda inserts that were 7 retail.
einy (Forum Supporter)
einy (Forum Supporter) Dork
11/1/21 12:42 p.m.
Honda inserts for their vehicles last the longest from my experience.  The inserts seem to be coated with a gray material ... graphite, maybe?  Typically run $4 to $5 each.
Tom_Spangler (Forum Supporter) GRM+ Memberand PowerDork
11/1/21 1:23 p.m.
Bosch Icon or GTFO.
Jesse Ransom
11/1/21 1:28 p.m.
Beam blades don't seem to work on the driver's side of the Mini. It missed enough area and skittered and squeaked enough with a Bosch Icon on there that I swapped it shortly for whatever the Rain-X "hybrid" was (I didn't realize this sort of new-fangled cross between beam and steel spring had a name). Nominally a step down from "beam" construction, bot works better on this shape of windshield.
I need new wipers, and they were out of everything hybridish at Napa... I wonder whether Bosch does one in that construction.
bobzilla
bobzilla MegaDork
11/1/21 1:29 p.m.
In reply to einy (Forum Supporter) :
I got them at 10% over cost so I paid like $3
Kendall_Jones
Kendall_Jones Dork
11/1/21 1:33 p.m.
I like the ford motorcraft "premium" wipers from rockauto.  After 10 years in the PNW I found them the best bang for buck.
I once had a set of Bosch wipers I put on right before a rainy trip from Seattle to Portland.  In the 4 hour drive the far outside passenger side left some black goo from the wiper and smeared it throughout the arc.    I don't know if they didn't like the windshield curve, but they made a chattering noise the whole trip and also made a mess.  They were expensive too.
JoeTR6
JoeTR6 Dork
11/1/21 1:46 p.m.
In Virginia, I use to put Rain-X on my windshields to extend the life of wiper blades.  Here in Colorado, it's not really worth it because the sun and grit take out wipers.  I miss the days when you could buy the Bosch Micro-Edge inserts for a decent price at the FLAPS, but now I usually go with the Michelin hybrid blades that Costco sells because of what Keith said.
Ranger50
Ranger50 MegaDork
11/1/21 2:03 p.m.
In reply to John Welsh :
Them Menards ain't much found below the mason dixon line...
codrus (Forum Supporter)
11/1/21 2:26 p.m.
Yeah, same thing in California.  No rain all summer means you need new wiper blades every fall when it starts raining.  So I just hit rockauto to order inexpensive blades for every vehicle I own in November.
preach (fs)
preach (fs) GRM+ Memberand Dork
11/1/21 2:43 p.m.
Bosch Icon on my summer car and my winter truck. New Hampshire.
No Time
No Time SuperDork
11/1/21 2:48 p.m.
I'm too lazy to keep up with rain-x applications, but find the Rain-x windshield washer/deicer provides a noticeable benefit if given enough time/use.
11/1/21 2:52 p.m.
Holy crap! Looks like I'll be ordering some cheap wipers from Menards - thanks!
Ranger50
Ranger50 MegaDork
11/1/21 3:06 p.m.
In reply to Pete Gossett (Forum Supporter) :
Was $7.85 shipping to Florida...
Tony Sestito
Tony Sestito PowerDork
11/1/21 3:15 p.m.
I've been using Trico Neoforms on my DD's for years. A little cheaper than the Bosch Icons, and they work just as well. Great in the winter and the summer months.
My older stuff either gets traditional winter blades or metal framed wipers. Just tossed on some of Autozone's cheapest Duralast metal frame traditional wipers on my truck after my wiper linkage rebuild, and they work well enough.
11/1/21 4:52 p.m.
That is a smokin' deal!
RevRico
11/1/21 5:11 p.m.
Yea that was my experience when I was still in Cali. Went from the Bosch icons I run in PA to the cheapest thing I could find because they'd inevitably melt to the windshield when I actually needed them. And at $20/side, it adds up quick.
I made it a habit to squirt the fluid every single time I turned my car on just to keep the blades moving and try to keep them clean.
TurnerX19
TurnerX19 UltraDork
11/1/21 7:48 p.m.
In reply to Tony Sestito :
I recently had an Autozone wiper blade fail on my Volvo. 16" blade waas only a few weeks old and the assembly rivets failed and pitched the drivers side blade onto the ground. I looked at the other side, and it was getting loose too.
Raze (Forum Supporter)
Raze (Forum Supporter) UltraDork
11/1/21 7:53 p.m.
Tom_Spangler (Forum Supporter) said:
Bosch Icon or GTFO.
This times eleventy billions...mods please close thread.
Tony Sestito
11/1/21 8:11 p.m.
In reply to TurnerX19 :
YIKES. I'll have to watch out for that!
Woody (Forum Supportum)
11/1/21 8:13 p.m.
Bob said something nice about Honda.
jmAcfZifcpIkunkVas78HhPrATXZxNDWAOYZLvtCo9pCPmnx6suBcTrzuG2Cyn05
