BradLTL
BradLTL GRM+ Memberand HalfDork
4/12/12 7:25 a.m.
Just curious... how far are you going into your tear down before building up?
I would put our tear down at 99%, and we are about to separate the body from the chassis and do a complete chassis up build. Does that make use the norm or the exception?
JoeyM
JoeyM GRM+ Memberand SuperDork
4/12/12 7:47 a.m.
You didn't fabricate your chassis from scratch?
(just kidding)
93EXCivic
93EXCivic UltimaDork
4/12/12 8:22 a.m.
Mine has the interior gutted right and I am removing the sound deadening and pulling the engine soon and then paint.
MG Bryan
MG Bryan Dork
4/12/12 8:26 a.m.
JoeyM wrote: You didn't build your entire car out of other people's garbage?
Fixed.
mndsm
mndsm UberDork
4/12/12 8:29 a.m.
As far as I have to.
westsidetalon
westsidetalon Reader
4/12/12 8:32 a.m.
had our Mirage down to a bare shell on a rotisserie at one point
JoeyM
4/12/12 11:39 a.m.
Fixed.
Thanks.
JThw8
JThw8 UberDork
4/12/12 11:45 a.m.
We got about this far when building ours :)
oldtin
oldtin SuperDork
4/12/12 11:57 a.m.
Bare shell - then cut rusty metal out of bare shell.
PseudoSport
PseudoSport HalfDork
4/12/12 12:20 p.m.
Eventually everything but the subframes and dash were removed from my Miata. My problem was I needed to keep the car movable so I was not able to strip it all down at one time and had to work on it in stages. That made things take twice as long.
0614081818 2010-08-07 18.04.22
jsymonds
jsymonds New Reader
4/12/12 4:25 p.m.
Lesson learned: leave as much of the factory primer in place as possible!
92CelicaHalfTrac
92CelicaHalfTrac MegaDork
4/12/12 4:27 p.m.
Tear down? E36 M3, i bought mine in running (barely) and driving condition, and i've been daily driving it since.
Tear down? There will be no tear down.
I MIGHT pull the motor out of it to clean up the engine bay this summer before i make the trip.
The car MIGHT get its first bath in the time i've owned it before the event, but it's not likely. It looks much better when it's in filthy "weathered warrior" status.
Nashco
Nashco UltraDork
4/12/12 5:26 p.m.
I took the $2011 N600 down to the absolute bare shell...and then I started cutting big holes in it. When there was only about 200 pounds left, I stopped. I don't think this is the norm OR recommended.
Bryce
Argo1
Argo1 GRM+ Memberand Reader
4/12/12 5:43 p.m.
Bryce- I don't think that we are too far behind you. The stripped out Lotus body shell weighs easily less than 200lbs. Then we just have the backbone chassis. It is quite an education to to take apart a Lotus. Lots of things that you want to take apart are glued together to save weight.
corytate
corytate Dork
4/12/12 8:24 p.m.
We are essentially done taking things out. the only things left in the interior are the steering shaft and the brackets to hold said steering shaft in place. I am leaving the factory cubby holes because the car will be driven occasionally on the street. gotta take the hideous tint off the hatch glass and then we're done stripping it. everythings out of the engine bay except the engine itself. that'll come out sooner or later. After we get the interior patched up and painted ALL the suspension is coming off, being cleaned, questionable parts replaced, and then hopefully reassembled correctly lol.
On second thought, the damn brake lines are frozen onto the master so I still haven't gotten that out of the bay either. not reusing it so I'm about to just cut the bastards out; we'll be running stainless and all replacement oem parts for braking to save budget for suspension and cool stuff.
wheels777
wheels777 Dork
4/13/12 6:09 a.m.
2008
http://cam777.synthasite.com/
2009
http://paccracing.synthasite.com/1-5.php
2010
http://morris777.yolasite.com/
Nashco
Nashco UltraDork
4/13/12 9:12 a.m.
Argo1 wrote: Bryce- I don't think that we are too far behind you. The stripped out Lotus body shell weighs easily less than 200lbs. Then we just have the backbone chassis. It is quite an education to to take apart a Lotus. Lots of things that you want to take apart are glued together to save weight.
Chassis? Not sure what that is, on the N600 the body and the chassis are the same thing.
Bryce
80qErZXXLJcdC1J227ki27RCQplgDtEsiegUbTB10Z9HD76bsAoYO4YEgm3Vx6Yw
