bvanepps
bvanepps None
4/16/09 2:06 p.m.
Any advice as to the hot pressures for track use? Thanks
motomoron
motomoron New Reader
4/16/09 2:50 p.m.
On an e36 M3 (-3.2 F, -2R camber) I ran 35-37 F and 33-35 R for autocross. At a track day I grabbed the tire gauge that had been dropped and subsequently read 3-4# low, and got 'em all pretty aired during a mid day session, probably close to 40R, 45F. They get beyond greasy to downright skeery.
I'd start about 7 or 8 pounds below where you want to end up, and add or subtract after the first session.
Also, RE01Rs don't handle heat well. Once they get toasty the grip gets shady. I sprayed the hell out of 'em after every autocross run and it helps, but buying Direzzas helps a lot more.
Duke Dork
4/16/09 4:14 p.m.
So lower in the rear helped get rid of understeer? I've got an E46 325i and with the pressures balanced it plows a bit on the RE-01Rs. So I should start a couple psi lower in back?
aussiesmg
aussiesmg Dork
4/16/09 6:34 p.m.
I always run lower in the rear, but my cars are usually heavier in the front.
iceracer
iceracer Reader
4/17/09 11:28 a.m.
A tire is like a spring. Higher pressure raises its rate. Stiffer in the back reduces under steer.
UkL0yk7wb2CvuHJseBZuH6CUNjW7bvvTM69Lum69CqJpOKd1Z47pQw7kh66SPFjq
