Well, kinda sorta ;)
Mini Dacon 928, from Brazil, which apparently used actual Porsche 928 taillights and other obvious styling cues. I never knew this existed but it is awesome :)
What with all that.... space in back, I'd think the 928 would be a good candidate for an actual rear engine conversion. And by space in back i mean awkwardly bulbously large rear end.
Vigo said:What with all that.... space in back, I'd think the 928 would be a good candidate for an actual rear engine conversion. And by space in back i mean awkwardly bulbously large rear end.
I actually had a similar idea, but with my 968. With its rear transaxle, and quite a bit of space between the front of the transaxle and the backs of the seats, it's at least theoretically possible to fit a compact engine back there, and convert it to a mid-engine car.
vazbmw said:In reply to irish44j :
I feel tricked
Thank goodness. The first couple responses didn't even seem surprised....
Cloud9...68 said:Vigo said:What with all that.... space in back, I'd think the 928 would be a good candidate for an actual rear engine conversion. And by space in back i mean awkwardly bulbously large rear end.
I guess the real question is :why would you even want to? The 924/944/968 have pretty ideal weight balance as it is. I would think making it mid-engine would actually make it handle worse, not better.
I never thought I would see a car that makes a 914 look pretty in comparison. I can admit when I am wrong.
I guess in that ‘80’s movie where Tom Cruise gets out of his 928 and exclaims “...Porsche. There is no substitute...” he hadn’t seen this.
In reply to A 401 CJ :
I've always wondered if the engine sounds in Risky Business are actual sounds made by a 928 or if they are just some random engine sounds put in there during editing.
Mainly as a way to save a ton of weight. It would get rid of the heavy iron torque tube, and the 968's engine is very heavy - its crank alone weighs 55 pounds, plus you have the balance shafts. This daydream of mine would be powered by an all-alloy 13B rotary engine, so the conversion would knock at least 300 lb out of the car. Plus, as duclberson says, 50/50 isn't necessarily ideal - there's a reason every race car at the highest echelons of the sport is mid-engined, as well as virtually every high-end exotic, and even the next Corvette.
