racerdog
racerdog None
4/3/11 1:51 p.m.
My new race car is festooned with stickers. Some come off easily, others are quite difficult and leave a lot of glue behind.
Any suggestions on how to remove the stickers and glue gunk without removing paint?
Much thanks!
Racerdog
Maroon92
Maroon92 SuperDork
4/3/11 1:58 p.m.
Goo Gone
dogbreath
dogbreath New Reader
4/3/11 2:12 p.m.
Use a hair drier or a heat gun on loooow to warm the adhesive. It doesn't need to be HOT enough to damage your paint, just warm enough to soften the adhesive. Helps a LOT.
fasted58
fasted58 Reader
4/3/11 2:14 p.m.
Heat gun, & wipe residue w/ what maroon said.
White_and_Nerdy
White_and_Nerdy Reader
4/3/11 2:15 p.m.
Maroon92 wrote: Goo Gone
Agreed. I once bought a Mazda B2200 from the courier company I worked for at the time for very cheap. It came with all the company decals still on it. Some careful work with a razor blade got the vinyl off, and lots of Goo Gone plus my buffer got the residue off afterward. The hair dryer idea sounds worth a try too.
former520
former520 New Reader
4/3/11 2:47 p.m.
I have had better luck with the eraser wheels also know as pin strip removers.
aussiesmg
aussiesmg SuperDork
4/3/11 2:55 p.m.
I agree with moderate heat and gentle methods to lift the corners and peel the heated area of the decal. Had great success this way.
fasted58
fasted58 Reader
4/3/11 2:56 p.m.
Use No razor blades. Let the heat gun do the work, move it around over the vinyl, don't concentrate in one spot, doesn't take a whole lotta heat either, pull easy, it will take most adhesive w/ the vinyl. Wipe residue w/ goo gone or even lacquer thinner.
akamcfly
akamcfly Reader
4/3/11 3:11 p.m.
"goo gone" is better than "goof off 2" - I haven't tried the original "goof off"
mw
mw HalfDork
4/3/11 4:37 p.m.
I often use laquer thinner instead of goo gone. It doesn't remove the paint unless the paint has been recently applied.
killerkane
killerkane Reader
4/3/11 5:13 p.m.
Goo Gone or tar remover. I used cheap Turtle Wax tar remover and it worked well.
neon4891
neon4891 SuperDork
4/3/11 5:46 p.m.
+1 on Goo Gone
DeadSkunk
DeadSkunk HalfDork
4/3/11 6:42 p.m.
Heat gun + gasoline.
SupraWes
SupraWes Dork
4/4/11 4:55 p.m.
Zippo lighter fluid or equivalent.
failboat
failboat Reader
4/4/11 5:03 p.m.
WD40
Woody
4/4/11 5:25 p.m.
Decal Eraser.
http://www.aircraftspruce.com/catalog/cspages/decaleraserwheel.php
2ORjY7Rwstb3Oqvw6XaglQTsDacNJdOLEHjx5jdYHjNjFMFExDpL0uvdQFVuUlYf
