So, my offspring ran over something in the road (don't know what) resulting in a blown front tire and a hole in the gas tank (2016 Toyota Rav4). The car was towed to the dealer. I can get a salvage yard gas tank put in or I can get a new tank for $500 more. What's the downside to the salvage gas tank? I'm guessing rust and crud in the tank that shakes loose when it's removed could lead to plugged fuel filter / fuel pump and further trouble but I'm not sure. Should I spend the extra for the new tank?
I would have no problem with a used Toyota OEM gas tank for a 2016 car. It's probably a lot better than the new aftermarket ones available. I don't imagine there's any rust or crud in the tank in a 2016!
In reply to dculberson :
Yeah, I wouldn't expect much crud in there either but I'll admit I haven't looked into many new(ish) gas tanks. That was about the only thing I could think of as a downside to a used tank. I suppose that there may be older RAV4s of that generation that could donate a tank (not sure when that generation started) but still they shouldn't be more than another couple of years older. I just wanted to see if that was what other people expected and to see if anyone knew of any other potential issues. Thanks.
In reply to 1988RedT2 :
Used is $170 and new OEM from Toyota is $650. I'm having the dealer do this so I don't know that an aftermarket piece from Rockauto is an option.
Titan4 said:In reply to 1988RedT2 :
Got it.
2016 is new enough to be most likely fine, and if the dealer is doing the work, I'd say you are correct. Price seems reasonable. Good luck!
