Grtechguy
Grtechguy MegaDork
3/23/20 1:24 p.m.
Maybe I'm reading to much into this.    I believe the PCM in the Wife's Town and Country is failing (spark issue, transmission control issue).
Is it junkyard part swap or do I really need to have the replacement reprogrammed to the VIN?
Curtis73
Curtis73 GRM+ Memberand MegaDork
3/23/20 1:51 p.m.
Depends on the year.
Some years, nearly any ECM will work.  Others, it has to be the exact part number and reflashed for VIN.
Vigo
Vigo MegaDork
3/23/20 10:05 p.m.
Im a sucker for chrysler vans, so i'll bite. What exactly is it doing?
Grtechguy
Grtechguy MegaDork
3/24/20 7:43 p.m.
In reply to Vigo :
Shutters between 45 and 55, random miss fires.
Seems down on power.
Seems to be hunting gears 4 through 6
I've replaced coil, wires and plugs.  Still have random missfire
Transmission also has had fluid changed recently to try to resolve the shifting.
Van currently has 108k
Donebrokeit
Donebrokeit UltraDork
3/24/20 8:47 p.m.
What year and engine, EGR?
Grtechguy
Grtechguy MegaDork
3/25/20 11:42 a.m.
2010 with the 3.8L,  6 speed auto
Donebrokeit
3/25/20 12:41 p.m.
Before trying to repair any trans issue make sure the engine is running well with no issues. Beyond checking the fluid level and leaks.
As for the miss-fire, what code(s) are you setting, have you done a compression and leak down test, fuel pressure? Any strange brake issues or "hissing" noise coming from under the dash, and dose this van have EGR?
Grtechguy
Grtechguy MegaDork
3/25/20 1:34 p.m.
It's pulling a P0113 IAT Sensor.   Watching live data confirms it is reading temperature correctly.  Unplugging it does read the expected -40 volts
P0301 Cylinder 1 missfire.   I have new plugs, wire and coil
I have not done a compression test or fuel pressure.   The fuel pressure may not be a bad idea to check.
Yes, It does have an EGR valve.
QUqNZNlQDOnyP4cQVxyMCW3D5tYADNt9yEif0xLL4cz7widoMxfKRoIzdGmcDNAx
