SVreX
SVreX MegaDork
10/15/12 8:36 p.m.
My daily driver is an F-250 Powerstroke, with a Reading steel contractor utility cap on it.
Looks like standard work truck stuff- you pass something similar every day. It's got a couple of ladders on top, and tools, etc. inside, but it does not look overly laden, sits straight, doesn't squat.
I knew it was heavy, because it don't drive like my Rabbit.
But today I had the chance to take it across a scale. It was loaded as I drive it regularly, not loaded down like I occasionally do, nor towing a trailer like I do quite frequently.
In standard daily trim, it tipped the scales at 8200#.
That's over 5 times the weight of my Rabbit.
Gives me a whole new perspective on the engineering challenges of what I drive, and a great deal of respect (fear) for all those other work trucks I see out there.
Even with over 4 tons on board, I still get over 20 mpg regularly. Gotta love a diesel.
HappyAndy
HappyAndy Dork
10/15/12 8:49 p.m.
Thats outstanding fuel mileage! My previous work truck was a Sprinter. Its every day weight was very close to yours, and it just barely made 21mpg.
SVreX
SVreX MegaDork
10/15/12 8:52 p.m.
I usually get about 22 mpg. Drops as low as 18 mpg when towing.
It's chipped, but that's the only mod. Still running stock exhaust.
Duke PowerDork
10/15/12 8:54 p.m.
We weighed my father's '69 Bonneville wagon in normal load out, with the rear jumpseats removed and the resulting secret compartment full of the usual tools and spare car wash parts.
5800 pounds.
Appleseed PowerDork
10/15/12 9:29 p.m.
You haven't seen loaded until you meet a scrapper with a loaded 1/2 ton.
mtn
mtn PowerDork
10/15/12 9:42 p.m.
Appleseed wrote: You haven't seen loaded until you meet a scrapper with a loaded 1/2 ton.
That is not even a half ton
DILYSI Dave
DILYSI Dave MegaDork
10/15/12 10:16 p.m.
My 2002 2500HD with an open trailer, an 89 Civic, some tools, spares, and luggage, crossed the scales at 14,000#. I was stunned.
HiTempguy
HiTempguy SuperDork
10/15/12 11:49 p.m.
DILYSI Dave wrote: My 2002 2500HD with an open trailer, an 89 Civic, some tools, spares, and luggage, crossed the scales at 14,000#. I was stunned.
How about towing across the country with a regular cab, long box duramax 2500hd... total rig weight, 22,000 pounds
Worst experience ever, so uncomfortable it's mind boggling. And then recce'ing with said truck.
novaderrik
novaderrik UltraDork
10/16/12 1:55 a.m.
my truck- 87 GMC regular cab long box body on 79 K2500 chassis with a small block backed by the HD iron 4 speed trans with HD iron transfer case and 14 bolt rear end and Dana 44 front end- is a mere 5300 pounds empty with half a tank of gas and me in it.. i had it just about to 10,000 pounds with one load of scrap iron..
DILYSI Dave
10/16/12 6:37 a.m.
How about towing across the country with a regular cab, long box duramax 2500hd... total rig weight, 22,000 pounds Worst experience ever, so uncomfortable it's mind boggling. And then recce'ing with said truck.
At 14k, it was a dream. Comfy, had plenty of balls left, may have accidentally seen triple digits, etc....
SVreX
SVreX MegaDork
10/16/12 6:38 a.m.
The empty kerb weight of my truck is 4894#.
I've towed lots of heavy loads (20K +), but I was pretty surprised to realize that I was hauling regularly so much "before loading" in tools, etc.
81cpcamaro
81cpcamaro Reader
10/16/12 7:09 a.m.
novaderrik wrote: my truck- 87 GMC regular cab long box body on 79 K2500 chassis with a small block backed by the HD iron 4 speed trans with HD iron transfer case and 14 bolt rear end and Dana 44 front end- is a mere 5300 pounds empty with half a tank of gas and me in it.. i had it just about to 10,000 pounds with one load of scrap iron..
About the same as mine. 79 GMC C3500 Dually regular cab, small block, SM465 trans, Dana 70 HD rear (2WD), it weights 5500 lbs, empty, GVWR is 10,000 lbs.
I need to weight my truck and trailer sometime, curious to see what it weights. I estimate it is around 14K.
81cpcamaro
81cpcamaro Reader
10/16/12 7:10 a.m.
DILYSI Dave wrote: At 14k, it was a dream. Comfy, had plenty of balls left, may have accidentally seen triple digits, etc....
I don't think my truck has ever seen triple digits even empty. But with low gears and without overdrive that is to be expected. It may fly apart at that speed for all I know.
wae
wae New Reader
10/16/12 7:13 a.m.
I gained a totally new respect for towing when I took my parts car to the scrapyard and found that my van + trailer + car was almost 10,000 pounds. Figure in some extra tires, tools, fuel, and other sundry items, and I'm sure that when I'm towing to a rallycross I've got 5 tons to keep out of other people's trunks...
GameboyRMH GRM+ Memberand PowerDork
10/16/12 8:02 a.m.
8200lbs is around stock weight for that truck from the specs I'm seeing online.
Ranger50
Ranger50 UltraDork
10/16/12 8:15 a.m.
I have never weighed my 97 F250 2wd extended cab long box PowerStroke diesel, but based on my 1/4 mile MPH, I weigh about 6-6500#.
fidelity101
fidelity101 Reader
10/16/12 8:28 a.m.
10,000 lbs you for your truck eh...
thats cute, this is what I deal with at work.
80k-100k
:P
except right now there are a lot of these because their full power brake system is garbage.
(couldn't resist to troll, sorry)
Appleseed PowerDork
10/16/12 8:34 a.m.
Add the fact that log semis are driven by complete nut jobs....
81cpcamaro
81cpcamaro Reader
10/16/12 8:34 a.m.
Yep, fidelity, your trucks are bigger. No CDL, special tags or DOT issues (well for the most part) with our trucks. Not to mention my neighbors wouldn't be happy with a Class 8 truck parked at my house.
DaveEstey
DaveEstey Dork
10/16/12 8:37 a.m.
I think my F250 oil burner crewcab long box weighs in empty around 7,900. I can cruise around getting 20-21 mpg all day. Even towing the 28' goosneck with the horse we averaged 16 mpg after sitting in traffic in CT and again in NY.
It's amazing how well these things hide their weight.
wae
wae New Reader
10/16/12 8:56 a.m.
In reply to fidelity101:
My mother-in-law's husband drives the nastiest hazmat he can find for a living and he was pretty un-impressed, too. :)
He says the really crazy guys are the tandem trailer drivers, though.
Bobzilla
Bobzilla UltraDork
10/16/12 8:56 a.m.
Our 06 1/2 crewcab is 5100lbs empty. This year's tow to lincoln with the STC Civic, trailer, tires, tools people, coolers etc was just shy of 10k lbs on a 4.8L V8. We averaged a tick over 15mpg round trip and it was an easy tow.
I wish it could "accidentally" see triple digits, but the nanny-on-board limits the top speed to 96mph.
Cotton
Cotton Dork
10/16/12 8:58 a.m.
my 95 Dodge cummins extended cab long bed dually 2wd is a lightweight....it's right around 7200 with me in it and some fuel.
fidelity101
fidelity101 Reader
10/16/12 9:23 a.m.
Appleseed wrote: Add the fact that log semis are driven by complete nut jobs....
Yeah I don't drive them, I work for the people who make the components that make class 8 vehicles. I have a hard time backing up my 20' car hauler with my 85 suburban granny 4 speed lol.
Driven by crazies, repaired by morons.
fastEddie
fastEddie SuperDork
10/16/12 11:51 a.m.
QpgiWDfqnNSsfJQYDl4Y4C5b4nYh7IZf8HRbAnDwERLPoGLi9ZJleiguyqZ1KQ7w
