markwemple
markwemple UberDork
12/1/17 4:28 p.m.
My 94 RRC 4.2 may need, or desire, new injectors. I've heard Ford 5.o injectors are a good upgrade. A wide variety of options. How does one figure out which ones to use?
airwerks
airwerks Reader
12/1/17 4:30 p.m.
What is an RRC?
markwemple
markwemple UberDork
12/1/17 5:15 p.m.
Range Rover Classic
BoxheadCougarTim
BoxheadCougarTim GRM+ Memberand MegaDork
12/1/17 5:18 p.m.
What's the reason to upgrade the injectors? I'd expect stock injectors to be the best choice for a stock engine with a stock, non-mappable ECU.
markwemple
markwemple UberDork
12/1/17 6:08 p.m.
High mileage and, supposedly, more hp and better fuel economy. Originals don't have the best spray pattern.
markwemple
markwemple UberDork
12/2/17 7:54 a.m.
Anyone with info??
dean1484
dean1484 MegaDork
12/2/17 8:23 a.m.
Get cc an or lb/ hour and the ohms of yours. Then start looking at the specs of the fords and match them up.  Wiring may also be an issue unless the plugs match.
markwemple
markwemple UberDork
12/2/17 8:26 a.m.
Can you go up on flow rate?? (in other words, is it a good idea)
BoxheadCougarTim
12/2/17 10:24 a.m.
The ECU will still try to hit its target AFRs, so unless you're planning on reprogramming that, I don't see how more flow may be beneficial and may actually cause issues if the increased flow means that it'll cause problem in low flow - like idle/small throttle opening -  situations.
Better spray pattern is probably more beneficial.
CqoACkJmiW5cndSwZKMyiAqOvipTftSOqKtcCMcYBB7rhNFATZbiT8dEcdaorst0
