So I'm looking into cheap & easy ways to paint my $2017 Challenge car, and one of the cheapest options with a good selection of colors is Rustoleum's American Accents Ultra-Cover 2x paint (it's like $3.50/can at the mart of walls). I've only ever really used Rustoleum's Stops Rust spray paint or the factory paint-matched ones (like Duplicolor)- has anyone else used the 'American Accents' pain on a car? How well did it work? Thanks!
(Example- not what I'm looking at using... or is it???) Rustoleum American Accents Paint
Here's the short version of the car being painted this weekend:
Took 13 cans (11 white 2 green). White was pretty difficult to work with, the green was awesome and super easy. The car was down to at least 400 grit sandpaper all over though, that probably helped.
I painted the Locost and my car hauler with Rustoleum Professional and a HF HVLP gun that I saw on super-sale yesterday for $9. I almost bought another spare, but, you know, just didn't really need it.
In reply to Wall-e :
It's the saab "truck" that I am representing the chicagoland GRMers with at the challenge this week. Huge team effort build by a lot of cool people. I am thrilled with how well it came out, I hope to make everyone who helped proud!
EDIT: I should say 'midwest' GRMers, since a few folks came from further than just the other side of the city!
So it works well? Does it live up to their claims about one coat covering enough to not need a second? Despite their saying it doesn't need primer I'm still likely to finish primering the Rampage since the front end is already in primer...
In reply to Dr. Hess :
I've considered that- but I don't think I could find the colors I want here in time...
Ashyukun said:So it works well? Does it live up to their claims about one coat covering enough to not need a second? Despite their saying it doesn't need primer I'm still likely to finish primering the Rampage since the front end is already in primer...
The green, yes; the white, absolutely not. I've heard yellow and white paints always struggle to cover though, and I have certainly fought that battle with yellow interior wall paint too.
Also, the green was really easy to see the 'wet spot' while spraying, which you need to make sure each pass connects the wet spot of the prior pass with the wet spot of the new pass for the paint to flow out evenly. If you don't you will have tell tale spray paint 'lines' (ask me why I had to paint three coats on the hood). Lines are easier to fix than runs though, so not the end of the world. Lines mean you aren't using enough paint and runs mean you used too much. You can always add more paint but the reverse is harder...
I can say I didn't have a single tip clog on me. That's kind of impressive. And I had a little overspray on the passenger glass that cleaned up easily with mineral spirits. My index finger still feels like your foot feels when you sit on the pot too long (er, read GRM too long) and your legs fall asleep.
I learned you don't have to move the can fast, but if you are spraying the can needs to be moving. Watch where the paint is hitting the metal, not the spot you are trying to hit (very weird, but works). The can says 12-18 inches away, and they mean it. The pattern is small, but overlapping the current pass over 1/2 of the last pass is a good goal to shoot for.
Finally, its all in the prep, and that is what takes the time. The actual painting goes pretty fast.
I should add - I am super pleased with the final product. I had a little bit of spray paint experience before this project but not a lot (before the weekend I bet I had used 20 cans of spray paint in my life on small stuff here and there). I was able to learn as I went. You can do it!
Warning about rustoleum: it can, and probably will, interact with real paint. I had that issue recently. Just a word of caution if you are considering real paint and body later.
Dusterbd13 said:Warning about rustoleum: it can, and probably will, interact with real paint. I had that issue recently. Just a word of caution if you are considering real paint and body later.
As in it's fine to paint over real paint with rustoleum, but the reverse doesn't work.
spraying a lot of cans of paint?
https://www.grainger.com/product/RUST-OLEUM-Spray-Can-Grip-2ERK5
I have one of these and its kind of awesome, but it looks like there are more comfortable ones out now if you search around.
I got one of those grips (like linked above) about 3 years ago.. That's one of those things that I'm kicking myself for not getting sooner! For <$5, the quality of my spray painting has gone up exponentially, way less runs, much better application, etc. Now it feels a lot like using the HVLP gun I've shot cars with, it's very controllable.
Yeah, I probably should have got the grip too. Considering my finger still isn't 100% back to normal...
