RoadWarrior
RoadWarrior New Reader
2/16/09 8:41 p.m.
Hey guys, So, I'm officially getting sick of the open diff in my 94 base model miata. And the lack of junkyard miatas here leaves the pickings slim to nil for finding an LSD rear on the cheap. So...I was reading that supposedly the 86-91 lsd's from NA RX7's are a boltin affair for the 94+ rear. So...there any way other than pulling the entire rear off the RX7/ or contacting mazda with the vin to figure out if it got an LSD or not?
bamalama
bamalama Reader
2/16/09 8:54 p.m.
It'd have to be a 5 lug car, and I'm fairly certain only then a GXL, GTUs (the s is very important) or Turbo II would have one. I've had four 5 lug FC's: Two Turbo II's, a GXL, and a GTU, and the GTU was the only one without an LSD.
Woody
Woody GRM+ Memberand Dork
2/16/09 8:56 p.m.
PM sent.
Grtechguy
Grtechguy SuperDork
2/16/09 8:56 p.m.
I have a Turbo II rear end in my garage in working order.
actually, I have the entire suspension from an 88 Turbo II, etc
ArtOfRuin
ArtOfRuin HalfDork
2/16/09 8:58 p.m.
Bamalama's right, only the GXL, GTUs, and Turbo II came with LSDs. The LSD's that came with the GTUs FC3S are viscous, the other two are clutch-type. If you get a clutch-type, it may be worn out and require a rebuild. IIRC, those plates are not cheap.
bamalama
bamalama Reader
2/16/09 9:08 p.m.
I also think the ring and pinion are different between the turbo and NA rear ends. Not sure what effect it has on compatability with a Miata.
ArtOfRuin
ArtOfRuin HalfDork
2/16/09 9:20 p.m.
They are. Currently sniffing around rx7club.com and rotarycarclub.com for the details...
RoadWarrior
2/16/09 9:30 p.m.
Yeah, I found a few guides saying NA ones will fit on Miata.net and a few other's during my searches of the intertubes. Seem that the turbo II LSD is requires more modifications to install.
bamalama
bamalama Reader
2/16/09 9:35 p.m.
Look for GXL's then. The GTUs (assuming you ever even see one) came with a TII diff.
YaNi
YaNi New Reader
2/17/09 1:45 p.m.
N/A limited Slips = 7" ring gear
86 Sport - clutch type
86-88 GXL - Clutch type
88 GTU - Clutch type
89-90 GTUs - Viscous type
All turbos came with a limited slip but 8" ring gear.
John Brown
John Brown SuperDork
2/17/09 1:50 p.m.
No one has considered an LSD blotter joke yet...
psteav
psteav GRM+ Memberand Reader
2/17/09 2:04 p.m.
How cheap is "cheap"? I've got a Type II Torsen (just the diff) that I'd sell you for $250 shipped. If you want a Torsen.
If you're set on a clutch type, there's a pretty good writeup archived on Miataturbo.net on which cars have the parts you need, and which parts those are.
RoadWarrior
2/17/09 4:32 p.m.
Type II for a miata for 250? I'm definately interested! Pm sent. That's about the price range I was lookin for.
bruceman
bruceman New Reader
2/17/09 7:06 p.m.
A 1st Gen Rx-7 LSD unit fits the 2nd Gen Rx-7 non Turbo models and therefore is also going to fit a Miata.
cVybQLtvpPX4cNPAzAB6lVGhaTAkyrjGsSuC1WvQtSKBSzWuuryyE6m4qqVGCmxj
