I am going to try to piece together a drive shaft, it seems like a rx8 manual drive shaft might be about the correct length.
I am struggling to find which slip yoke they use though, if it is the wrong one is it pretty easy to swap in a GM 27 spline like on the manual Colorado and th350's use?
By counting splines, measuring the ID of the seal and the shaft diameter I was able to find a Spicer 1330 yoke for my CD009 in my truck. It's supposedly for some 90's Toyota 4x4 but works perfectly. Summit and a lot of off-roader type retailers have most of that info cataloged and you can sort through slip yokes by a few of those parameters.
Bear in mind that Mazdas since 1984 have staked in U-joints and are technically non servicable. You can buy replacement U-joints with inner circlips, but the flats on the inside of the yokes are not precision machined, so the joint will run off center.
Teh E36 M3 said:Also bear in mind- the RX-8 driveshaft is carbon on the manual models.
Came here to write this. The automatics have a classic steel driveshaft though
In reply to Stampie (FS) :
Not this again
It's 25 spline. The two missing splines are not keyed, they are simply there so that fluid can transfer out if the driveshaft has to plunge. I haven't seen a slip yoke that didn't have that.
It is the same as FD and Turbo II, and FC-up automatics. Supposedly there is an early Torqueflite 904 slip yoke that fits, I haven't ever seen one.
