DjGreggieP
DjGreggieP Dork
11/22/23 12:44 p.m.
I have a door handle problem.
My 98 BMW 328is has broken door handles on the drivers side. The door can be opened by pulling what's left of the handle forward and it may be repairable with some JB weld and an extra screw (VIN tagged as 'destroyed' in the system, never going to be anything BUT a track car, pretty is far, far down the list of requirements) which isn't a terrible problem.
The issue is the exterior door handle. Its broken, and from what I can see, not an easy fix. It's also no longer available. I have seen them pop up on eBay, but I'd rather leave them in circulation for someone trying to keep a street car useable / enjoyable.
It's primary function will be a drift car, but have recently thought about possibly taking it to some drag racing and maybe some time attack (like a Challenge competitor car) to try and get more use out of since even if I attend every drift event, that's 4 weekends from June to October.
So can anyone direct me to what would pass tech for an exterior door handle? I'd hate to come up with something that works, drive with the car on a trailer and be turned away in the techline because of a door handle.
Ranger50
Ranger50 MegaDork
11/22/23 1:12 p.m.
I had a buddy remove his broken handle on his mustang by fishing the rod out and putting a socket on the end covered in electrical tape to satisfy the rules.
DjGreggieP
DjGreggieP Dork
11/22/23 2:05 p.m.
I was scanning the WDRA rules and *nothing* is noted about door handles. I may need to try a longer rod and a socket on the end maybe. Paint it neon green so its easy to see.
APEowner
APEowner UltraDork
11/22/23 2:26 p.m.
As long as it works and is easily identifiable as a door handle you should be fine but, as always, the best way to be sure is to ask an inspector for the sanctioning bodies you want to run with.
Toyman!
11/22/23 2:36 p.m.
I have used a loop of cable and some rubber tubing as door handles before. As long as the function is obvious pretty much anything can be a door handle.
TZktTaebu1jhfoqJPzZymZP560fzofl14vvpGAitr1HxpsWOqrclpWse1TFLGuRH
