glueguy
glueguy GRM+ Memberand Reader
10/7/13 11:39 p.m.
Goofing off on CL this weekend I came across this
http://tampa.craigslist.org/hil/cto/4068695928.html
and I'm intrigued. I've never had a rotary before and have never really paid attention. I would probably keep it for a year and put 3k or so miles on it. What do I need to look at to know if the motor is sound or if there is major concern? Where are the rust areas on FB's?
What's the best online group to go learn about them and find experience?
Thanks for the advice. Scare me away or enable me.
Hungary Bill
Hungary Bill GRM+ Memberand HalfDork
10/8/13 12:15 a.m.
I don't really know of things to "listen for" but the baby should "purr like a kitten".
Do you have a compression tester? If so, a compression check is always a good idea. Instructions here: Rotaryresurrection tech
also, Rotaryresurrection has some good tech articles worth reading.
for forum support there's RX7club.com and nopistons.com. I've spent plenty of time on both, but when I sold my last 7 I was partial to rx7club.
good luck man. Be forewarned the rotary tends to be a bit addictive. It was 10 years before I bought another piston powered car
fidelity101
fidelity101 Dork
10/8/13 7:12 a.m.
yes, you should. Especially that one! I've never seen an interior like that before.
the FBs like to rust around rear wheel wells and near the rear bin area behind the seats.
TxCoyote
TxCoyote New Reader
10/8/13 7:47 a.m.
Price is high but you pay for condition. If it is truly as described it will be less headache and cost less in the long run.
belteshazzar
belteshazzar UberDork
10/8/13 8:25 a.m.
provided you care for it, I don't see that car losing much value
free rental!
aussiesmg
aussiesmg MegaDork
10/8/13 9:18 a.m.
fidelity101 wrote: yes, you should. Especially that one! I've never seen an interior like that before. the FBs like to rust around rear wheel wells and near the rear bin area behind the seats.
To check for rust under bins, look inside wheel well above wheel for signs and remove the bins to check properly, bring a good quality Philips screwdriver to do this, the screws will be tight if never removed before.
Check drainage from sunroof and rear hatch, hint a piece of 1/4 flexible plastic is perfect to run down these drains and clean them out, do it regularly.
aussiesmg
aussiesmg MegaDork
10/8/13 9:23 a.m.
Find out if they did a "Rats nest removal", it is a good thing unless you want to restore to original.
Check the oil lines are actually bringing oil into the intake, I usually remove these then premix with 2 stroke 50-1 ratio instead of relying on sump oil.
Is there other mods to the engine and what are they.
Good, Racing Beat exhaust, 2nd gen lead coil swap, carb upgrade.
Easily get 150hp with these few mods.
Check steering for famous "Wander steer" there is some adjustment available but not a lot.
glueguy
10/8/13 4:50 p.m.
Hard to believe it's been 5 years since I had a car with window cranks and almost 20 since I had a car with a carb.
Curmudgeon
Curmudgeon MegaDork
10/8/13 5:00 p.m.
Suh-weet. I agree the price is a bit high but if it really is rust free in the spots previously mentioned, runs strong with no smoke or overheating then it would probably be worth it. I don't see a sunroof which generally means it's a GS but the ad mentions limited slip which was a GS-L thing. It might be a bit of a hodgepodge.
aussiesmg
aussiesmg MegaDork
10/8/13 5:03 p.m.
GSL rear is a very simple swap, GSL-SE means you have to do the front hubs to match.
1988RedT2
1988RedT2 UberDork
10/8/13 6:20 p.m.
Not many '82's left in that nice a condition.
amg_rx7
amg_rx7 Dork
10/8/13 6:21 p.m.
Yes. Absolutely yes.
Ranger50
Ranger50 PowerDork
10/8/13 6:27 p.m.
"Duh."
banzaitoyota
banzaitoyota Reader
10/8/13 6:40 p.m.
Absolutely :-) !
Rotarycarclub and nopistons are good forums
CKJmnmdUTOLthxhvLD8CvNLpZSoeM69QSMh0pXYfOLERbri3vkD9zsx3ACn9DjUD
