WildScotsRacing
WildScotsRacing Reader
12/9/15 5:33 p.m.
Bust a nut!
Kenny_McCormic
Kenny_McCormic UltimaDork
12/9/15 5:41 p.m.
I've lived in Michigan my whole life and am often pleasantly surprised what can be accomplished by a good application of pb blaster, tapping the nuts/bolts/thread areas with a hammer, pb blaster soak again, and then going to town for a long lunch. Stuff tends to come apart when I come back to it.
If you've got a torch of some sort (even propane), even better, with the aid of heat I've seen exhaust nuts removed that were see through in places.
Dusterbd13
Dusterbd13 UberDork
12/9/15 5:51 p.m.
I'll try this after work tomorrow Kenny. Single dad tonight.
jere
jere HalfDork
12/9/15 7:59 p.m.
Take it from someone in the rust belt country, penetrating oil, propane torch, penetrating oil, propane torch... repeat and see if the bolt is loose in-between (I cant even change the brake pads without using this method).
The best penetrating oil to use with heat is a homemade mix of vegetable oil and acetone 50/50 or so. I put it in gravity style oilers or an empty sriracha bottle. This will get 100% of bolts out if you dont get impatient and torque the bolt heads off or whatever.
benzbaronDaryn
benzbaronDaryn Dork
12/9/15 8:48 p.m.
I used the small nut buster on a grade 8 metric bolt, the splitter and nut both busted at the same time, that was fun.
Kenny_McCormic
12/9/15 9:24 p.m.
If you're mixing penetrating oil, add GL5 gear oil, the EP additives keep things from galling when halfway apart.
7jNCFTzShScWXAiZsKBAwJ1TxSn3oiuGE1LdSyrCqVj39oDzmw4CBpTCfgbtI6Dk
