Klayfish
Klayfish Dork
5/10/13 7:00 a.m.
Finally...we have a decent weather day here in PA. Not cold, not raining. So I brought my NA Miata to work today. First time the car has seen the light of day since sometime in December. Before taking it out, it got fresh oil and I poked around underneath to make sure everything is tight (though I'm not a great mechanic).
Car runs great, sooooo happy to be driving it again. However, I noticed over bumps that the rear end is a bit squirrely. Not as in completely out of control squirrely, but I definitely feel it. I noticed it a tiny bit last summer, but it's more noticable now. Ideas?
N Sperlo
N Sperlo UltimaDork
5/10/13 7:03 a.m.
Make sure the sway bars are bolted up nice and tight.
EvanB
EvanB GRM+ Memberand PowerDork
5/10/13 7:37 a.m.
Take the sway bars off and just go full speed over the bumps.
N Sperlo
N Sperlo UltimaDork
5/10/13 7:45 a.m.
Don't listen to Evan.
z31maniac
z31maniac PowerDork
5/10/13 7:48 a.m.
All in your head because you aren't used to driving a vehicle that is so responsive?
N Sperlo
N Sperlo UltimaDork
5/10/13 7:53 a.m.
He said Miata, not P71.
Klayfish
Klayfish Dork
5/10/13 7:56 a.m.
z31maniac wrote: All in your head because you aren't used to driving a vehicle that is so responsive?
Funny you say that. I spent my winter driving my '01 Saab 9-5 wagon. And if I wasn't driving that, I was driving the family truckster minivan. My Saab is fairly responsive, but my minivan not so much...part of me was wondering if I was just sawing at the wheel out of habit...
N Sperlo
N Sperlo UltimaDork
5/10/13 8:11 a.m.
Check the sway bar before assuming.
peter
peter HalfDork
5/10/13 8:26 a.m.
tire pressures?
Sky_Render
Sky_Render Dork
5/10/13 9:00 a.m.
Stock or aftermarket sway bars?
kazoospec
kazoospec HalfDork
5/10/13 9:02 a.m.
Similar experience with mine when I got it out. Double checked the tire pressures and found some variation between them. Adjusted pressures, viola, solved.
BoxheadTim
BoxheadTim GRM+ Memberand PowerDork
5/10/13 9:29 a.m.
How old are the shocks?
EvanB
5/10/13 9:32 a.m.
N Sperlo wrote: Don't listen to Evan.
Pshh, I have no swaybars on my Miata. It makes the commute to work more fun bombing over rough roads.
Matt B
Matt B Dork
5/10/13 9:32 a.m.
Shotgun.
N Sperlo
N Sperlo UltimaDork
5/10/13 9:58 a.m.
Bring it to the Back40.
wbjones
wbjones PowerDork
5/10/13 9:59 a.m.
Matt B wrote: Shotgun.
is that your solution, or where you want to ride ?
Klayfish
Klayfish Dork
5/10/13 10:18 a.m.
The car is all stock suspension, including sway bar and shocks. Don't know how old the shocks are. I know the previous owner (who was also the only owner) said he replaced them, but I don't have a receipt. I checked tire pressures when I was changing oil, so there all even. I'll put it on jackstands over the weekend and take a closer look at the swaybar.
qM6hcU1cJ2XxzIXdOSroknpBu7xsqH1Xt7828XAthQbsTXe3G5wgU3Vuei1lt2rT
