Racingsnake
Racingsnake Reader
4/25/22 10:32 a.m.
Not sure if I have the terminology right. Basically I want to be able to inflate a tire without the valve stem in place - I find the increased airflow helps to seat the bead easier when installing tires.
I also want the chuck to either clamp on or preferably screw on to the valve stem so I can keep my hands free to help manipulate the wheel and tire to get the bead seated.
Any recommendations?
wae
wae PowerDork
4/25/22 10:44 a.m.
I assume you mean without the valve core installed in the valve stem?
The way I seat a bead is to take out the valve core and then screw on my air gun attachment:
Then I plug in the air line and press the lever.  If I need to hold the tire to the rim, I'll put some Velcro or a zip tie around the lever for hands-free operation.
Toyman!
4/25/22 11:02 a.m.
Any tire machine chuck will do what you want.
Coats-Euro-Chuck
Racingsnake
Racingsnake Reader
4/25/22 8:51 p.m.
Perfect, thanks guys
chandler
chandler UltimaDork
4/25/22 9:06 p.m.
This is what I like, silly expensive so you can't drop the hose when you are done with it or the body cracks.
On car tires it's not as big a deal but I work on semis and the 100-110 psi makes it a bigger deal.
Racingsnake
Racingsnake Reader
4/25/22 9:09 p.m.
Luckily I think that's probably overkill for me
dqgWAsOVEkYSWzF6tCbbruCmC21x7IE4UZDM2I5nH36GrCo9OZfHZXlXVV2mXTuD
