3/13/25 6:33 p.m.
I had last changed the Toyobaru's brake fluid last spring. Then I crashed it and it sat at a shop the whole year, went into storage late last year with only a few hours of driving time on it, and now I'm getting it ready to go on the street again. I was curious about what condition the brake fluid would be in, hoping I might be able to get away with not swapping out barely-used brake fluid but expecting that the amount of use made no difference to its condition. A couple years ago I bought an electronic brake fluid tester, unfortunately the shape of the brake MC reservoir on this car makes it impossible to get the tester probes immersed, so instead I pushed some fluid out of one caliper and ran the test on that.
And when I dipped the probe in, it read...no detectable water content, 0%, just like testing in open air. Even though it had just passed through a bleeder bottle's valved tube setup and been deposited into a random plastic cup. This was my first time using the tester and I thought maybe it was faulty, so I tested it in a bowl of water. It jumps right to the top of the moisture scale as soon as the tips of the probes touch the surface. So I guess the brake fluid is still pretty much good as new. Maybe that's how it was last spring too, I'll be testing before blindly changing fluid from now on.
GCrites
GCrites Dork
3/13/25 6:39 p.m.
If it sat then the fluid might last longer due to lack of heat cycles.
3/13/25 7:16 p.m.
It absorbs fluid from the air. That must be a very nicely sealed brake system, with a rubber diaphragm between the fluid and the outside air instead of a vented cap.
adam525i
adam525i GRM+ Memberand SuperDork
3/13/25 9:33 p.m.
It would be interesting to compare to a sample from the master cylinder if you can extract some.
3/13/25 10:04 p.m.
In reply to adam525i :
I can give that a try next time if I draw some out with a pipette, unfortunately I already skewed that test for now by topping up the MC...
8Qt0BEDcKW1k3Lz1D8aZkITqNdS8UFzLPKAdSkCU7JRzfbhz3GUq1ZhGOJ7haL5r
