ditchdigger
ditchdigger Reader
4/28/10 10:29 p.m.
Ok so for the time being I am running a very small weber carb on my Fiat. Back when I first bought the car I scored a NOS Weber 30icf (the factory carb) for under $5
Just like this one.
Over time I "upgraded" to the 2 barrel Weber 30DIC and went with a 286 cam and higher compression but I could never get the idle circuit to work properly (questionable old carb rebuilt by myself with a 30 year old OE weber kit.) and after a while got sick of the crappy cold starts and constant massaging of the throttle to keep it idling so I bolted on the old single barrel. RESULT!!!! instant awesome idle, choke works great, absurd fuel economy (like 55mpg) and low end performance was rather improved but of course the top end where it used to pull hard to 7500rpm it now starts to peter out at 4500.
Anyway back to the point. I had a few minutes to spare so I swapped out the main jet from a 1.15 to a 1.25 to see if top end would improve, and it did by quite a large margin. It pulls pretty good until 6800rpm. The problem is that now the choke doesnt work any more and there is a large bog from 2000 to 3500RPM.
Should I have stepped down on the air corrector instead? Should I have changed them both? What is the correlation between the two? This carburettor black magic thing is confusing to a simple Megasquirt based caveman like myself.
MS is on the way. Just need a few more bits to finish it up. Photobucket
drmike
drmike New Reader
4/28/10 10:51 p.m.
I used to work with DCOE carbs a lot. On those carbs, a larger air corrector would lean out the top end. To put it another way, the main jet affects the entire fuel curve (except for idle and just off-idle), and the air corrector affects just the top end.
motomoron
motomoron Reader
4/28/10 11:24 p.m.
Talk to the nice people at Pierce manifolds. They know all about Webers. Also, there's a book published by (I suspect) motorbooks international on this ever-more arcane topic. In my case (hot 1275 BL "A" engine w/ a 45 DCOE) the David Vizard A Engine bible had most of what I needed to know.
Persistence and keeping good notes is very helpful...
1XNSeRuACmK12oSPiGeeXejzdNm6VcwpL7PkhzeIHFnGDfXiLQjKI7VkVl09XqyN
