mazdeuce
mazdeuce Dork
5/22/13 2:40 p.m.
Thanks for this thread. Because of the chatter about timing I decided to check the timing on the wagon. The light said that it had 28 degrees of initial advance. I set it back to 10. I also found a loose spark plug. Thank god for old industrial strength engines with 8.5/1 compression. Hopefully nothing permanently bad happened.
Kenny_McCormic
Kenny_McCormic Dork
5/22/13 6:05 p.m.
Another thought, looking at the vac diagrams, it appears the distributor vacuum advance is(was) on some sort of switched vacuum maze. Its currently hooked to manifold vacuum and has a funny off idle stumble, it will bark the tires, fall in a hole and the come back out. Should I have it hooked to a port vacuum source before the throttle plate so the advance comes on rather than fall off when I stomp on it?
Googling the subject gets a lot of noise about American V8s and nothing else.
5/22/13 9:36 p.m.
can you get a centrifugal advance distributer from an X1/9 or a 128 and just swap the electronic ignition?
Kenny_McCormic
Kenny_McCormic Dork
5/22/13 10:16 p.m.
I COULD, but the Bosch centrifugal/vacuum transistorized system in place works great, and as shown in the build thread, handles abuse/my stupidity quite well. I've also got it all figured out so it cant strand me on account of a loose ground or other such bullcrap.
Such parts are also rather pricy and you don't see too many 30+ year old SOHC Fiats at the junkyard in MI.
Kenny_McCormic
Kenny_McCormic Dork
5/24/13 1:12 p.m.
Switched to a vac port near the venturi area that was dead at idle and jumped when you stab the throttle, now the little bugger will actually launch! First time I left the gravel parking pad I accidentally spun the tires, it gained that much low end. I can actually grab the next gear on the factory ~4500 rpm shift points and it will pull immediately.
5/24/13 3:06 p.m.
i had a feeling you were leaving something on the table with a vacuume advance distributer with no vacuume
Kenny_McCormic
Kenny_McCormic Dork
5/24/13 4:18 p.m.
Yeah, it now runs like an engine designed by a guy who used to design Italian race car motors should. That is, Eh, ok, POWWERRRRRRRR*. Rather then, eh, WTF YO, GO GOD DAMMIT, power?^
*About 60 horsepowers, maybe.
^Lose drag races with old naturally aspirated diesel school buses.
Still need to put a light on it and crank it up to 12 degrees, it was too bright today to see the marks.
TkGPSLSweTaBHMTZYhfB6V2o6S0ciRTwA8ovp3lC6obReQpXSh2y0IxJfhYX9J1l
