3/5/15 4:56 p.m.
Vigo wrote:
I have 9" wheels, not real interested in running 205s.
Well, if they run the same width on the same rim then the difference would be like a 205 hp car and another 205hp car with a +20hp sticker stuck on the side.
But they don't. The wider wheel width will increase the tread width. That's one reason tire spec sheets always identify what size wheel was used at the time of measurement. You also get better support for the sidewall.
But a 205 on a 9" wheel is getting into stance territory. That's too far.
Stancey said they were at Discount Tire.
sesto elemento
sesto elemento Dork
3/5/15 9:06 p.m.
I run ra1s in that size on the spyder
Vigo
Vigo PowerDork
3/5/15 9:26 p.m.
True, and the stated tread width for the 225 was probably on a wider wheel then the 205 was measured on, meaning if they both came up with the same tread width the 205 was REALLY wider.
Still, i understand this idea of not buying 9" wheels just to run 205s. I wad just pointing out the irony of responding to a 225 and 205 measuring the same by saying my wheels are too wide for 205s when they measured, you know, the same.
beans
beans Dork
3/9/15 6:43 p.m.
Rival is now available in a 215/45/16, too.
Vigo
Vigo PowerDork
3/9/15 7:21 p.m.
I have some old rs2s in that size on a 16x7.5 and it's a pretty great wheel/tire size combo if it fits the car you're searching for. Unfortunately it's a bit small on my stock-height 626.
Swank Force One
Swank Force One MegaDork
3/9/15 9:45 p.m.
225/50-16 works well on stock 626. So does 205/55-16.
Vigo
Vigo PowerDork
3/10/15 9:26 p.m.
Yeah, i kinda wanted to buy the 225/50/16 Advan A048s on closeout on TR back when there was a full set but i knew that was kinda ridiculous for a stock suspension DD car.
xvyZ5WX10sATPku3ImM55WcVam6qbllcQjFGNIuePecy5cjGsgTidAeOxPO38WDq
