lrrs
lrrs Reader
1/14/17 2:29 p.m.
First, I need a return line, original car did not have one. So the thought was to place a T in the exiting line between the pump and the tank. After more thinking, not always a good thing, I have become concerned with trapped air being circulated around causing issues. If I had a dedicated return all the way to the tank, it would get bled out back at the tank. Is the T idea going to cause me issues with trapped air or will the air work its way out thought the injectors after a short run ?
Next, the fuel pump, looking at a generic Bosch 044 equivalent, this will fuel a NA Subaru EJ22, any reason why I should not go this route ?
Thanks, Steve
Knurled
1/14/17 2:39 p.m.
A tee will probably cause a problem because it will have an extremely hard time drawing from the tank. Adding return lines isn't terribly difficult.
Bosch 044 would be thermonuclear overkill for fueling, but (if a genuine 044, not a fake) will last more or less forever and will have so much overcapacity that even if it got badly heat soaked, you'll be fine. I did manage to kill one, I think from constantly getting air in the inlet making it cavitate or something. Installing a surge tank stopped my car's appetite for fuel pumps.
Stefan
1/14/17 3:02 p.m.
I second the surge tank idea. Circulate the fuel through there so the air can be separated properly.
lrrs
lrrs Reader
1/14/17 4:12 p.m.
Thanks.
Any recomendations on fuel pumps other than the 044? When searching summits site there are about 400 options, a lot don't list the psi.
Thanks again, Steve
HpcG8gpJGsMtlIBtiUWlPa5PRVQ849KpnD5WMjLjeUKBqIvXZdKTiSD0Y3nePJw0
