Realize I forgot to update this with a post-rally-x recap. First, good news: I won my class! And, my co-driver took second! Pretty easy to place 1-2 when you have the only car in your class.
The old Volvo, by Colin Chapman's theory, turned out to be a "perfect racecar". Which is to say, it pretty much broke at the checkered. After the last of the 8 or 10 total runs, my co-driver was idling it over to the trailer and noted the shifter was in a weird position, and the steering pulled hard to one side.
Both motor mounts had sheared clean off; the engine was sitting cocked sideways in the engine compartment. As for the second picture, the driver's side upper control arm had pulled out of one of its mounts, giving some severe caster on that side. While the Pit Crew looked on, I loaded up the banged up Amazon and we headed home to change and head out for a post-race celebratory dinner at my favorite brewery.
The next day, some post-race damage assessment...
We'd broken a few exhaust hangers about halfway through our runs, and the field-improvised repair was holding up, but barely.
The engine dislocation had tugged on the lower radiator hose, bending the radiator outlet. Seeing as how this radiator had never been touched in the decade or so I've owned this car, I'm planning on just replacing it.
I tried tightening the UCA bolts on the driver's side, but they wouldn't go- I guess the bolts stripped out the holes. So, the engine's gotta come out so I can repair the stripped out holes in the crossmember. Just as well, since the engine mounts all need replacing.
The "To-Do Before The Next Rally-X List", in its current, ambitious state:
