logicfactory
logicfactory New Reader
8/27/11 10:32 a.m.
most that i have come across need to be bolted in and resemble the following image; i am searching for a hub that will work with a spindle(?) type setup like the following image; some of the miata ones i have seen look the part but i was hoping some qualified people could give me a definitive answer. i am specifically looking for a 4x100 solution. i believe the e30 bmw has what i am looking for but may use a little to small of a wheel bearing for what i am willing to do.
8/27/11 10:38 a.m.
the top one looks like a FWD hub.
I know the Fiat 124 has a spindle.. but it is 4x98
pres589
pres589 Dork
8/27/11 10:53 a.m.
Probably a number of japanese rwd imports from the 60's to 80's use the style of spindle you're looking for with the bolt pattern you want.
What about Ford Fox parts? Bolt pattern is different but parts are cheap and wheels are common, etc etc.
SkinnyG
SkinnyG HalfDork
8/27/11 11:02 a.m.
Chevettes are allegedly 4x100. I run Chevette spindles on my Locost, but with Datsun 210 hubs to get me 4x114.3 (thanks 44Dwarf!)
Chas_H
Chas_H New Reader
8/27/11 12:14 p.m.
The hub is the easy part-what spindle are you using?
logicfactory
8/27/11 12:22 p.m.
i will be using either the non m or m e36 spindle; from my understanding only difference being the spacing on the caliper mounting points.
if the shaft that the hubs mounts on is solid my initial thought is to just turn it down to the corresponding hubs i.d.
at this time, i do not have the shafts o.d. to compare to hubs.
8/27/11 12:28 p.m.
if you go with the M.. you can run the bigger M brakes or the 4 pot brakes from the 850
Non-M, you can run the larger brakes off of the E46 330i
Chas_H
Chas_H New Reader
8/27/11 12:42 p.m.
An NA/B Miata hub will likely do. If you are mixing and matching parts, there's no reason not consider a Miata spindle. BMW brakes are gonna need work to mount on anything other than the hub they came from.
44Dwarf
44Dwarf Dork
8/27/11 1:50 p.m.
SkinnyG wrote: Chevettes are allegedly 4x100. I run Chevette spindles on my Locost, but with Datsun 210 hubs to get me 4x114.3 (thanks 44Dwarf!)
Your Welcome! and thank you last thing i need is parts clogging up the house..
And yes chevettes are 4x100mm that what i run on the dwarf.
shuttlepilot
shuttlepilot Reader
8/27/11 3:23 p.m.
fast_eddie_72
fast_eddie_72 Dork
8/27/11 3:57 p.m.
That's the answer I had. Back a few years ago I convinced myself that I could find time to build a Locost. Of course, I don't. But I did research a few things and that's what I came up with. If I did have time, I'd love to do a true low cost using a rusty Chevette as a donor.
KATYB
KATYB HalfDork
8/27/11 4:01 p.m.
rear hub from a last gen prelude.
novaderrik
novaderrik Dork
8/27/11 8:05 p.m.
Vega/Monza
Pinto and Fox Mustang are also 4 lug and have that style of hub, but i don't know the bolt circle right off hand.
logicfactory
8/27/11 8:30 p.m.
thank you for the responses thus far. i have lots of research to do. i already plan on doing custom rotor and calipers so that part will not limit my options for hubs. i just have to look at how/if i can machine down my spindles to see what i.d. of the hubs i can play with.
thank you again for the responses. as i get more information i will share with the community.
Chas_H
Chas_H New Reader
8/27/11 8:33 p.m.
Good luck, here's some information that might help- http://www.ntn.co.jp/english/products/pdf/hub/pdf/HubBearing.pdf
Woody
8/27/11 9:27 p.m.
Lots of speculation here but maybe Fiero spindles and Chevette hubs might work together.
motomoron
motomoron HalfDork
8/27/11 9:49 p.m.
Bimmerworld has been blowing out new e36 M3 front spindles for $35 for ages. They have too many evidently, and will run out 15 minutes before I decide to finally order a pair.
novaderrik
novaderrik Dork
8/28/11 1:33 a.m.
it shouldn't be too hard to figure out something that will work- there are only a few different inner and outer bearing part numbers and you can find the spec for the i.d. and o.d of the bearings and the o.d. of the different bearing races to figure out what bearings you can use. i used to have a printout of all the different specs that i found on some website many years ago, but it's long gone..
anyways, you can take the bearing info and look up different brake rotors/hubs to find a combination of a hub and bearings to use with whatever spindle you wind up with. i used to have a parts list for putting the HD rotors (12"x 1.25" thick with a 5X5 bolt pattern) from an early 80's 1/2 ton 2wd GM pickup onto a Vega/Monza spindle..
Rocco R16V
Rocco R16V New Reader
8/28/11 2:08 a.m.
novaderrik wrote: Pinto and Fox Mustang are also 4 lug and have that style of hub, but i don't know the bolt circle right off hand.
4x108
Woody wrote: Lots of speculation here but maybe Fiero spindles and Chevette hubs might work together.
pretty sure fiero and chevette spindles are the same. except the '88 fiero
Jay_W
Jay_W Dork
8/28/11 7:30 a.m.
IIRC, Mistubishi galant/vr4. But only iirc, which is happening less frequently these days...
44Dwarf
44Dwarf Dork
8/28/11 10:00 a.m.
Woody is corect they do interchange How ever the stub height on some years fiero's is lower (factory drop spindel if used on vette) rotor / hubs are diffent 4 lug and 5 lug but bearings are same.
Hawk Macine out of NY makes caliper adapters to put wilwood brakes on the chevette spindel (bolt on alum adapters).
oldopelguy
oldopelguy Dork
8/28/11 2:37 p.m.
The Chevette, Fiero, and Opel hubs all use the same bearings and can mount to each other's spindles or the bolt on spindles from the rear of a Festiva.
Which lets you put Chevette front discs on the rear of your Festiva when you swap the front out with Aspire parts for a matching bolt pattern 4-wheel disc set-up...
mr2peak
mr2peak GRM+ Memberand Reader
8/28/11 9:39 p.m.
Toyota MR2 might work. But again small wheel bearings.
turboswede
turboswede GRM+ Memberand SuperDork
8/29/11 2:06 p.m.
Porsche 924, but it is 4x108 pattern. Seem to hold up to road race abuse, since it isn't much different than the 5-lug 944 hubs.
Chas_H
Chas_H New Reader
8/29/11 5:12 p.m.
mr2peak wrote: Toyota MR2 might work. But again small wheel bearings.
It will be quite difficult, perhaps impossible, to find a 4 stud hub with overly large bearings.
ZOakK43FtJAXJEzybYmDJNAHQLxdz2Hzj47FFvLS9Wk1hRBV3FAiQyuTJz0QErBy
